Home > General & Technical (L663) > What’s behind this panel?
RDR
I’m on the hunt for a place to stow my own jack, the plan to use space under the floor has been scuppered by the MHEV gubins. I unbolted the modules around the compressor but couldn’t quite make it work.
Before I start trawling the web does anyone know what’s behind this panel ? It seems separate to the side pod and I’m wondering if there is a void behind here to use if a fabricated something?
 110 MY23.5 X Dynamic HSE
RR MY23 HSE PHEV
D5 MY19 HSE - Now Sold
D4 MY16 HSE Luxury - Now Sold
D4 MY12 HSE - Gone
D3 MY06 S - Gone but not forgotten
Post #1018515 16th Dec 2023 2:51pm
umbertob
United States
If you had the 3-zone climate control with rear cooling assist option, that flat panel would be replaced by a grey plastic cover, bulging out into the cargo area about 4 or 5 inches, enclosing an auxiliary blower for the independent rear passengers and cargo area climate dials and controls. I did remove that panel in the past but don't recall how much room there was back there without the optional blower - must not be much though, considering how fairly bulky that cover is when the auxiliary blower unit is fitted. 2020 NAS Defender 110 HSE 5-seater / Silver / Khaki / Black Pack / Black Roof / Satin Film / Cold Pack / Off-Road Pack / Advanced OR Pack / Comfort + Convenience Pack / Sirius + HD radio / HUD / Meridian Surround
Post #1018519 16th Dec 2023 4:38pm
chpsk8
United States
Looks like it just pops off with clips. Get a panel tool and give it a pop and see what's back there.
What are you jack dimensions?
Post #1018537 16th Dec 2023 6:17pm
RDR
Thanks all and Yeh I’ll get it off tomorrow and see what’s what behind it even if it’s a little bit of space it will help I can fab a frame off it for the jack.
The jack is a powerbuilt All in One it’s basically a jack stand with bottle jack built in and my preferred choice after a JLR scissor jack failed on me Confused 110 MY23.5 X Dynamic HSE
RR MY23 HSE PHEV
D4 MY12 HSE - Gone
Post #1018540 16th Dec 2023 6:50pm
Moo
Ukraine
I'm intrigued by this. Look forward to seeing how you get on. I've wondered about whether I could store a better jack and kit behind the spare wheel. Eiger Grey MY23 D250 SE with bits. Known as Noddy.
Post #1018542 16th Dec 2023 7:22pm
RDR
Behind the wheel something I thought of too but would rather keep it out of the elements.
For reference my load space
This spot was close needed about 30mm more depth
I want the jack stored upright to avoid leaks. 110 MY23.5 X Dynamic HSE
RR MY23 HSE PHEV
D4 MY12 HSE - Gone
Post #1018544 16th Dec 2023 7:30pm
Moo
Ukraine
What jack is that? Looks good. Eiger Grey MY23 D250 SE with bits. Known as Noddy.
Post #1018546 16th Dec 2023 7:55pm
RDR
It’s a PowerBuilt all in one, very sturdy and safe it drops into the jack stand ratchets as you raise it then to lower you bump it up a bit, disengage the ratchet and lower on the bottle jack bleed screw. Been good for my Discoveries and the full fat.
RR MY23 HSE PHEV
D4 MY12 HSE - Gone
Post #1018549 16th Dec 2023 8:50pm
Moo
Ukraine
Thanks. Just bought one. Thumbs Up Eiger Grey MY23 D250 SE with bits. Known as Noddy.
Post #1018555 16th Dec 2023 10:45pm
stevemfr
France
Very cool jack/-stand. Thanks for the info!
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s,
2 FL1s and a L663 on the way
Post #1019187 24th Dec 2023 12:56pm
