![]() | Home > Technical > Extremely noisy fan |
andy63 Member Since: 30 Jun 2023 Location: north east Posts: 636 ![]() ![]() |
![]() Click image to enlarge I had to go and check the spanner I used, as I was sure I'd seen 32 stamped on that.... And it has 😩.. But I use it on the large nut which is 36 mm.. ![]() Click image to enlarge |
You are spot on ian👍.. It has been modified at some point.. And most probably by me... But I can not remember doing it.. I'm thinking it was for an old mk3 transit with the 2.5 Di engine and then modified for a mk7 transit... And it just happens to fit the 2.2l landrover.. 👍😂..
Talk about getting out more.. It can't be worse than lying under the truck putting the exhaust and props back in.. Hopefully tomorrow will get it finished.. And thanks for taking the time and sorry for the confusion🙃😩😂 |
