![]() | Home > Td5 > Td5 Starts, Runs and then cuts out. |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5792 ![]() ![]() |
Run the priming process on pump. How does pump sound?
Any of the relays under seat getting hot? Burnt terminals? Any vacuum when you take fuel cap off? |
Mdm Member Since: 11 Sep 2013 Location: Sunny Lancashire Posts: 1633 ![]() ![]() |
the fault code read points to a poorly ecu but double check wiring first or try a spare ecu and you'll soon know if the issue disappears.
crank sensor faults are normally different to what you have described same goes for worn out injector washers and your fuel level would be rising if they were that bad. |
Gingerbunny Member Since: 01 Oct 2013 Location: Wirral Posts: 5 ![]() ![]() ![]() |
Thanks for the help so far, the fuel pump sounds fine, can't see any damage to relays etc and none seem hot. Unfortunately I don't have a spare ECU to try; I'm going to send this one off to be repaired see how I get on then. Cheers, Luke
BaronDefenders Member Since: 28 Jun 2019 Location: London/Cotswolds Posts: 903 ![]() ![]() ![]() |
I’m afraid topside fault means the ECU has met its end.
Your options are either to send your current ECU away for repair or source an entire replacement. Charlie 1949 Series 1 80 (SOLD) 2002 Td5 90 (SOLD) 2008 Freelander 2 (SOLD) 1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored) 1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE) 2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK) 2012 Puma 110 Zermatt Silver (Overlanding Build) Instagram: @BaronDefenders |
Benny Member Since: 03 Nov 2016 Location: Plymoth Posts: 15 ![]() ![]() ![]() |
Hi. I had ecu issue. Tamar electronics in Ivybridge. I highly recommend.
Chris86 Member Since: 15 Jul 2014 Location: South Yorks Posts: 793 ![]() ![]() ![]() |
If it's TD5 ECU related and you need it testing/repairing- Dan at Storm Tuning would be my recommendation.
He's sorted a couple of problem ECUs for our customers, and usually has stock of replacements if it's either beyond repair, or the repair is not economical to do. Regards Chris |
