Home > Puma (Tdci) > Intercooler problem
Vmax
Gibraltar 2008 Defender 110 Puma 2.4 SW Baltic Blue
Intercooler problem
Does this require changing the pipe only or do l need to check more parts that could be damaged?
Post #1017879 9th Dec 2023 1:23pm
DAZ110
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Barolo Black
If one is splitting then it probably won’t be long before the other hose splits too. Better change them soon.
Post #1017886 9th Dec 2023 2:54pm
Vmax
So it's the hoses needs changing only yep.
Post #1017891 9th Dec 2023 3:08pm
Ianh
It should be just the two hoses that need replacing, one in, one out of the intercooler. Use silicon ones from Bell auto services or Allisport.
Post #1017895 9th Dec 2023 3:54pm
Vmax
Thank you very much for your help
Post #1017898 9th Dec 2023 4:16pm
JPE
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Firenze Red
If you still have trouble after changing those two, the intercoolers themselves can split at the seams & there's also a third hose low down & difficult to access going into the inlet manifold. Looks like you have the culprit in your photo though.
Post #1017906 9th Dec 2023 5:16pm
Ianh
I believe the OP has a 2.4, and therefor 2 hoses, where as the 2.2 has 3 hoses, including that difficult 90degree bend to the inlet manifold .
Post #1017907 9th Dec 2023 5:31pm
Vmax
Change three hoses.
Post #1017908 9th Dec 2023 5:31pm
Vmax
Two excellent
Post #1017912 9th Dec 2023 5:55pm
JPE
Sorry my mistake, change 2 ! Smile
Post #1017915 9th Dec 2023 6:26pm
Vmax
No worries 👍
Post #1017935 9th Dec 2023 9:06pm
