Home > Technical > engine height
paul 123
United Kingdom 1995 Defender 90 300 Tdi HT Auto Rutland Red
engine height
i have a problem with engine height. i am doing a chassis swap on a 300tdi 90. the chassis is a new galvanized one from richards the engine is from a 90 the gearbox is a discovery 300tdi automatic one new rubber mountings have been used . the problem i have is the front of the engine is sitting too low so the fan catches the cowling at the bottom.with the cowling on the radiator the fan cant be screwed on to the pulley as the thread is about an inch below where it needs to be.any ideas?
Post #1015872 21st Nov 2023 10:03am
geobloke
Best advice I can give is to drop Ashcroft a line and get their advice.
Post #1015875 21st Nov 2023 10:20am
Chicken Drumstick
Re: engine height
Do you have photos?
While it is possible there is something amiss with the chassis, it is unlikely as they will have been built on a jig.
Is the engine sitting at the right angle? Remember engine mounts only support the weight of the engine, location is also set by the gearbox mounting. The engine will essentially pivot or rock on its mounts moving the front of the engine up and down.
Post #1015884 21st Nov 2023 11:17am
paul 123
i have just measured the height of the mountings on the gearbox cross member the new one seems to be higher which would set the front lower. time to call richards chassis.
Post #1015892 21st Nov 2023 11:41am
paul 123
richards were helpful they are sending me some shims which should solve the problem.
Post #1015900 21st Nov 2023 12:20pm
paul 123
great service the shims were here in 24 hours.now to fit them at the weekend and hope it solves the problem.
Post #1016060 22nd Nov 2023 6:32pm
paul 123
now fitted the shims they have raised the engine up but not enough to get the fan on.
Post #1016346 25th Nov 2023 1:56pm
paul 123
a new cross member is on its way to me hopefully that will cure the problem. richards chassis are being helpful and trying hard to help with this problem. if i needed another chassis it would be from richards.
Post #1016801 30th Nov 2023 7:41am
paul 123
fitted the new gearbox cross member that sits the gearbox 10mm lower still cant fit the fan. next step was to measure another defender 300tdi . my engine is now in the correct place still the fan wont fit .it seems as if the wrong shroud has been fitted. now going to fit electric fan.
Post #1017507 5th Dec 2023 11:47am
NickMc
Some pictures might help Thumbs Up
Post #1017575 6th Dec 2023 1:04am
paul 123
i am fitting an electric fan today. it seems that i as trying to cure to problems at once without realizing that i had two problems. the problems were the engine sitting too low on the mounts this has been cured with the help of richards chassis by fitting spacers. the second problem was the wrong fan shroud. measuring another car proved my engine is now in the correct place. this car that i am rebuilding was bought as a running pile of parts.
Post #1017580 6th Dec 2023 6:01am
paul 123
As it is with the wrong shroud
Post #1017581 6th Dec 2023 6:05am
windy81
Wales 1992 Defender 90 200 Tdi HT Firenze Red
fit an electric fan kit. its a solution without the hassle of shims etc
Post #1017614 6th Dec 2023 12:07pm
paul 123
i will still need the shims as if i remove them the timing cover will be too close to the steering box.just tried to fit the fan which came as a kit yhe bolt holes for the fan and mounting frame dont line up.
Post #1017617 6th Dec 2023 1:06pm
NickMc
I think the problem is the chassis is wrong, that’s why the fan cowl doesn’t fit now. I would be getting the chassis replaced if it’s wrong, not accepting shims Shocked
Post #1017649 6th Dec 2023 6:57pm
