![]() | Home > Technical > BBUS Alarm Battery backup unit- Part codes |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3536 ![]() ![]() ![]() |
My 2012, not XS, but with a few extras, came with a BBUS. So my guess is that an XS should have had it.
Will be interesting to see how you replace the battery. Link to a similar attempt: https://www.defender2.net/forum/topic65058.html 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17718 ![]() ![]() ![]() |
By 2012 an XS would normally have had one, and if it left the factory without one it would not have the correct wing harness for one. TD5 vehicles had the connector whether or not a BBUS was fitted, but Pumas had a value-engineered harness without the connector unless a BBUS was fitted.
Peak.Land Member Since: 23 Nov 2023 Location: Peak District Posts: 5 ![]() ![]() ![]() |
My land rover was stolen at one point in its life so while I could see the connector for the alarm battery backup I could not see the unit with the headlight out. Should it be very easy to see with it out? Who ever stole the car did not remove anything from it more disable or unplug things
If it is in the factory location it should be visible with the bonnet open, look forward of the screen wash reservoir. It's a black cube with a single connector.
If a BBUS wasn't fitted at the factory there should be a simple alarm sounder horn there instead (a separate horn to the main vehicle horns). Be aware that most sensible folk relocate the BBUS to somewhere where it can't be accessed without opening the bonnet. If yours has been stolen and recovered someone may have moved it. |
That is interesting I did not know they fitted a simple sounder don't suppose you know a part code?
I will have another look I thought it was odd the connect just floating around loose behind the passenger headlamp Not seen many pictures of them installed |
