Home > Puma (Tdci) > Puma alarm NOT SOUNDING? |
dmtben Member Since: 12 Mar 2023 Location: Warwickshire Posts: 7 |
Bump (all out of ideas, please help!)
4th Dec 2023 9:41pm |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 1999 |
Do you have central locking ? If so is it still working ? Is yours a 90 or 110 ?
Things to check. Broken wires in the loom to each of the doors, this can cause a short and blow the fuse . It’s a common issue but I don’t think that’s the issue in this case but worth checking. Water ingress into the 10AS alarm module. Remove the driver footwell speaker, look up and attached to the bulkhead you will see a green box, that’s the 10AS alarm module. It’s attached to the bulkhead with two screws and has two harness connectors going to it. You can remove the connectors and 10AS to see if there is any water ingress or corroded pins etc. these diagrams will help. https://www.lrworkshop.com/wiring-diagram/...tem/active https://www.lrworkshop.com/wiring-diagram/...em/passive https://www.lrworkshop.com/wiring-diagram/....4tdci-rhd Last edited by Ianh on 5th Dec 2023 12:48pm. Edited 2 times in total |
5th Dec 2023 2:04am |
My defender is a 110 hard top, without central locking. I have a feeling you may be right about the door switches shorting out (this issue started after I had done some rust repair, including spraying rust inhibitor into the cavity they sit in). But I will also check the actual alarm module to see if the short is coming from that instead and will let you know. Thanks
5th Dec 2023 12:35pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17372 |
Assuming that the horn works normally, Check CJB Fuse 27 since this powers the horn when the alarm is sounding it. It might also be worth checking R200 (the alarm sounder relay) since this is probably what you can head clicking but is the thing that is actually causing the horn/sounder/BBUS to activate.
Do you have a BBUS fitted? If not, do you have an alarm sounder fitted? I assume that the 15A fuse you mention is Fuse 6 (since this appears to be the only 15A fuse associated with the alarm system). If so, this provides power to the BBUS connector, the Alarm sounder relay, and the alarm ECU, so unfortunately there are many places where a short could cause it to blow. It is likely that the blowing of this fuse will mute the alarm. |
5th Dec 2023 1:12pm |
It’s not the door switch’s, as they just extend a negative earth to the 10AS, however there are positive wires in the loom to the pillars that serve the doors, and in the case of central door locking go from the pillars to the doors where they can fracture and short.
Ps. Don’t forget the rear door. As BW states, check that relay and the wiring associated with fuse 6. |
5th Dec 2023 1:42pm |
