Home > Puma (Tdci) > ABS / TC |
bob neville Member Since: 30 Apr 2009 Location: Marbella Posts: 3248 |
Never had a problem with either on mine (2009 110).
Even with ABS stopping distance is a long way Bob |
22nd Nov 2011 7:20pm |
Fifth Horseman Member Since: 08 Mar 2011 Location: Lanarkshire Posts: 322 |
ABS will not improve stopping distances - remember it operates by releasing the brakes to stop the wheels locking.
Its not much help if all four lock at the same time, like on ice Where it will help is in helping you keep control if the wheels on one side of the vehicle lose grip. Traction control, which comes as part of the ABS can help maintain forward motion in certain situations. Most common faults seem to be with the cables to the sensors (I had one of mine replaced under warranty) or the shuttle switches in the ABS valve block, but are relatively easy to trace if you have a code reader that can read the ABS codes (Nanocom etc). |
22nd Nov 2011 8:23pm |
