![]() | Home > Td5 > TD5 Fuel Pump |
Next one
I know exactly what you are saying I did exactly the same thing, two Allmakes pumps later and the penny (or many many many pennies) finally dropped. Not had a problem since the VDO pump has been fitted. Well if and when you come to do the pump swap and you do not have one drop me a line and you can borrow the pump retaining ring tool ![]() |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2181 ![]() ![]() ![]() |
That’s very kind of you 👍
Jabberwocky Member Since: 27 Oct 2021 Location: Luxembourg Posts: 236 ![]() ![]() |
I’ve just upgraded to a 120 litre fuel tank, also changed the pump, old one worked fine but daft not to replace it when a new tank is going in.
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1235 ![]() ![]() ![]() |
You can't have too many good spares on the shelf, just in case! In fact Ideally you have known good spare car just in case.
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 968 ![]() ![]() ![]() |
There is a 120 Litre tank which fits OE specs??? 🤷♂️ 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
I presume it is this one https://www.johncraddockltd.co.uk/tr55-lon...09-on.html
![]() 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
kzycnn Member Since: 24 Apr 2009 Location: Northumberland Posts: 277 ![]() ![]() ![]() |
Safari Equip also do a 120 litre fuel tank https://www.safari-equip.co.uk/shop/land-r...ess-steel/
I have this one fitted to mine. Tony |
Alan Member Since: 10 Oct 2013 Location: United Kingdom Posts: 4 ![]() ![]() ![]() |
my td5 now takes 3 attempts to start, it fires straight away but stumbles for a second or 2 before stopping, fine on 3rd attempt and once running is perfect all day until next morning, changed injector loom as small amount of oil showing, injector seals, air flow meter. nothing has made any difference.
2004 td5 , 75 k miles. do you think it might be pump ? |
Or a leak in the fuel lines introducing air you are purging out.
