Home > Maintenance & Modifications > Easy fix to stop your handles seizing in the cold |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3685 |
Given them a good spray in the barrel with Abus lock lubricant. That used to keep mine from freezing up as it coats the internal with a dry silicone lubricant.
30th Nov 2023 1:03pm |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2108 |
Both good ideas
30th Nov 2023 7:25pm |
Love a simple idea
I confess to be fond of a good squirt of silicone spray around the push button and smeared onto the rubber door seals. Works a treat when icy conditions are forecast. |
30th Nov 2023 7:37pm |
Race.it Member Since: 27 Aug 2019 Location: Algeciras Posts: 826 |
Or just move to the south of Spain. Never had one freeze up down here Searching for my first Defender...and started just as Covid hit, so talk about timing.
5 months after starting the search I found it, and here is the details |
30th Nov 2023 7:44pm |
