![]() | Home > In Car Electronics (L663) > TPMS Issue |
Ritson Member Since: 11 Apr 2021 Location: France Posts: 193 ![]() ![]() |
I was alerted this morning by the TPMS that I had low pressure in the right rear tyre. Upon inspection I found a screw embedded in the tyre so swapped the wheel out for the spare. I set off again and the TPMS still showed me as having low pressure in the right rear tyre, obviously as the TPMS sensor is in the deflated tyre which is now on the rear door.
However, during a subsequent journey there was no warning so I checked the TPMS and found that now none of the tyre pressures are being recorded. Has anyone else had a similar issue? Cheers Current: MY22 P400e SE Prior: Discovery Sport HSE, Jaguar F-Type S, Discovery 3, RR Vogue |
Thanks for the reply. Fingers crossed mine does the same! Current: MY22 P400e SE
Yep, system has reset itself and all seems to be working fine. Thanks Current: MY22 P400e SE Prior: Discovery Sport HSE, Jaguar F-Type S, Discovery 3, RR Vogue |
whiterdesign Member Since: 10 Jun 2021 Location: Preston Posts: 275 ![]() ![]() |
I’ve had a low pressure on one tyre yesterday. Looked at all the pressures and they were all a bit low. Pumped them up to the required pressure and just started car and they all showed the new pressures, didn’t have to drive it at all. 110 XS 250 MY 23 Gondwana Stone, Cold climate pack and towbar
DFNDER Member Since: 02 Oct 2023 Location: Perth WA Posts: 140 ![]() ![]() |
Similar when you rotate thr tyres, it takes a bit for the system to work out which sensor is where.
I've found if just checking pressures and in or deflating tyres thr tpms reacts almost instantly. Sensors are accurate too. |
