Home > Puma (Tdci) > Optimill steering boss
Naycrx
Morning,
Come to fit our quick release boss this morning, the current mountney boss seems to slip on and off without to much pressure, the optimill one however seems very tight to fit on the splines? I can locate them on maybe 1mm of them , or is this correct? Suppose as the boss gets tighnted down it would go on further?
Post #1016410 26th Nov 2023 10:29am
rustandoil
I suggest a quick count of the splines to make sure you have the correct boss
Post #1016413 26th Nov 2023 11:11am
Naycrx
Yes I have just done that, 48 splines on the column and just checked part number, they have sent me a defender 48 slime boss......
Post #1016414 26th Nov 2023 11:19am
Naycrx
Sorry posted twice
Post #1016415 26th Nov 2023 11:19am
bodstruck
The 36 spline one on my Puma is tight. I always have to press it home screwing the nut in and have to use a puller to remove it.
Not saying that is right but perhaps not unusual.
Post #1016421 26th Nov 2023 1:04pm
Naycrx
Hmmm.... it will kind of located on around 2mm max of the splines, but I'm unsure about screwing it down incase it hasn't gone on correctly and damage the splines ?
Post #1016422 26th Nov 2023 1:41pm
swt
United Kingdom 2008 Defender 110 Puma 2.4 XS CSW Stornoway Grey
I had what sounds like a similar problem. See the following thread:
https://www.defender2.net/forum/post933204.html
The tolerances are fairly precise. I got a replacement boss from Optimill and all was well.
Post #1016429 26th Nov 2023 4:43pm
Naycrx
Brilliant sounds exactly the same . I haven't messed around woth it to much as I didn't want to scratch it etc. Were they ok with taking it back for an exchange?
Post #1016431 26th Nov 2023 4:58pm
swt
Customer service was excellent. I sent them some pictures, sent it back in good as new condition (like you, I was very careful with it) and a new one arrived by return, which slipped on very easily.
Post #1016432 26th Nov 2023 6:03pm
JAP
Likewise I had a 48 spline boss which wouldn’t drop far enough down onto the spindle to allow the bolt to secure it. I returned it after contacting Optimil and they sent me out a new one which fitted perfectly. It was obviously drilled out slightly more allowing it to drop sufficiently onto the spindle. Really good service from them.
Post #1016590 28th Nov 2023 12:11am
Naycrx
Quick update- I rang Optimill they explained that obviously tolerances can be out on there part or ours- therefore carry bosses in stock that are marginally larger - New one being sent today- Customer service was brilliant. Fingers crossed new one fits
Post #1016700 29th Nov 2023 10:43am
