Home > Puma (Tdci) > Vacuum Pump oil leak Puma 2.4
WPRO18
 2005 Defender 90 Td5 SW Cairns Blue
Bit of guidance please, my Puma 2.4 an early model is seemingly showing signs of oil forming around the Wabco vacuum pump. I only noticed today , but judging by the dirt, it has been doing it a little while.
It's not making a massive mess, but findings its way (presumably via the belt/fan) a little onto the adjacent rubber hose.
Now after a bit of googling I suspect it is the vacuum pump, however just wondered:
1) If it is the vacuum pump leaking, does it begin to get progressively worse before leading to failure ? If it does fail, what happens?
2) Is there anything around that sort of area that it could be other than the vacuum pump? (oil is trickling via the pump)
I couldn't get through to my local independent, but essentially they usually have long wait time before booking in (not mechanically able myself to replace unfortunately) . As such, is it likely to develop to full blown oil leak / lose all of the oil?
Just wondering if I can keep driving for now, I have a trip over the weekend and would be great to use my Defender.
Post #1016203 23rd Nov 2023 7:25pm
MK
Sometimes its bottom gasket fails and oil leaks. Puma 110" SW
Post #1016257 24th Nov 2023 1:47pm
Minch90
I’ve had 2 gaskets go and 1 pump fail. When the pump failed oil was around the pump spindle, with gaskets the oil was below the pump and gasket 2.4TDCI 90 - everyday brilliance
S3 V8 Lightweight - in the garage being ignored #newchassistime
S3 lightweight - 2nd car 24V fire risk with a full tilt and the windscreen down
S1 80" - first car fun - 75mph in neutral downhill once #wobblesallround
Post #1016378 25th Nov 2023 6:57pm
The gaskets leak if you overtighten the securing bolts. For once it is worth (a) using a genuine Ford gasket, and (b) using a teeny-weeny torque wrench.
Post #1016391 25th Nov 2023 8:32pm
SilverPuma
United Kingdom 2010 Defender 90 Puma 2.4 HT Stornoway Grey
I had oil film regularly around the inlet manifold, hp fuel pump etc. And it turned out to be the vacuum pump. As the viscous fan for the rad has quite a bit of power is spreads the leak into a fine mist on surrounding parts and pipes making it awkward to spot the cause. The gasket is a significant almost sandwich plate with rubber seal inset. Definitely worth paying up a bit for a decent one. 2010 2.4 TDCI Puma Defender 90
Post #1016425 26th Nov 2023 1:51pm
WPRO18
Thanks all, this should be getting sorted in the next few weeks. Car has been idle, as I've been away. I did take it out today and it seems to create the same level of 'mess' and not gotten worse.
Having said that, I was moving the car out today, after it sitting for quite a few weeks I'd taken it for a run and halfway through a motorway run it has flicked on the engine management light.
Car runs fine (pulls well and without the light, you'd not know anything was up) , but wondering if that vac pump could cause the dash light to come on / stay on?
Post #1019306 26th Dec 2023 4:27pm
