![]() | Home > P400e Area (L663) > Preconditioning not working |
DavesS Member Since: 03 Jul 2023 Location: Yorkshire Posts: 4 ![]() ![]() |
I was just about to create a post for the same issue re preconditioning. Plugged the vehicle in to charge yesterday afternoon, set a departure time of 6.15am in the precondition section of the app and the timed climate feature selected. When I got in this morning, nothing which is the 3rd time ive tried to no avail
Ritson Member Since: 11 Apr 2021 Location: France Posts: 192 ![]() ![]() |
I'm pretty sure you are not able to use electrical preconditioning if the car is plugged in. On the app it allows you select whether you use the petrol engine or battery for preconditioning power. Try using electrical preconditioning again but ensure the car is not plugged in. Alternatively leave it plugged in and select petrol engine on the app. See if the preconditioning works for you then. Current: MY22 P400e SE
Prior: Discovery Sport HSE, Jaguar F-Type S, Discovery 3, RR Vogue |
jimjamken Member Since: 01 Mar 2023 Location: Surrey Posts: 88 ![]() ![]() |
You can definitely use electric for preconditioning but the app doesn't always remember the setting for using the battery. My advice is to check about 15mins before the preconditioning starts to make sure the setting is set to battery.
yes you can use battery for preconditioning, just not while its plugged in Current: MY22 P400e SE
I definitely use it when it's plugged in so it draws the power from the EV charger rather than deplete the battery and range
ok, maybe its just because I only have the 'granny charger' ie the one that connects to a household socket, rather than a dedicated EV charging point Current: MY22 P400e SE
