![]() | Home > General & Technical (L663) > Has anyone swapped out the analog gauges for a full digital |
pjeski Member Since: 25 Jul 2023 Location: Michigan Posts: 113 ![]() ![]() |
I’ll let you know tomorrow.
Edit: Well, not bad, but it’s not quite done yet. It’s not something I would recommend trying yourself but it might not be impossible. There’s a lot of software flashing involved, apparently, as well as some extra wires to connect. The work is being done at Sarek. They’ve partnered with one of the prominent UK outfitters that has developed this retrofit apparently there’s a lot to it, and resolving the issues has been complicated be the time difference. We’re left with one issue that the map display is flashing back and forth to the “blank” screen, which is a side view of the defender. This is a 23 130. Hopefully the guys in the UK will have an answer in the morning. Once it’s resolved I’ll add more. |
Everything works great. There was a connection that wasn't snapped in correctly and once that was done, everything behaves as you would expect including the annoying dimming.
