Home > Puma (Tdci) > Transfer box plug drain undo impossible |
Defderico Member Since: 11 Dec 2020 Location: New Caledonia Posts: 16 |
Hello,
I just put back the transfer box on my 110 TDCi (2011) I did my oil change on the gear box, all good (2,3 litre) I wanted to fill the transfer box Impossible to undo the drain plug, even with an extension bar Any advice please? Do I have to weld a vry long extension bar to achieve this ? Many thanks for your help Éric |
19th Nov 2023 11:24pm |
Hello Ianh,
I made a mistake The fill plug is the issue I changed the clutch (to a LOF one) so the gear box and transfer box were drained If I heat all round the fill plug of the transfer box? Is this possible ? |
20th Nov 2023 2:57am |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 1982 |
Heat will help but you need to be carful not to overheat as it’s an alloy case. Obviously you need to ensure everything around,( especially above ) the area you are heating is protected / insulated from the flame. Plumbers solder mat is good for this. Have an extinguisher at hand just in case of an issue.
Aluminium alloy is a very good heat conductor so you can try heating with a plumbers propane torch, circling around the plug for 30 seconds, then trying the breaker bar, then heat a little more if it does not break loose. If it’s still not moving , with something like a 700mm breaker bar then my last resort would be heat followed by a high torque impact wrench, with short bursts on the trigger to see if that will break the plug loose, however that does risk stripping the thread if you go too hard. |
20th Nov 2023 11:22am |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8006 |
I wouldn't use heat on that casing or impact gun with high potential to thread damage.
Use a long extension bar. May have to lift vehicle. Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
20th Nov 2023 5:03pm |
JST - I agree that you have to be careful with heat on the alloy casing, I was thinking of just getting it to the same temperature as it would get to after a long run , to potentially soften any threadlock that has been used and provide a little expansion prior to hanging on the breaker bar / breaker bar with an extension.
20th Nov 2023 6:16pm |
v8bob Member Since: 14 Mar 2018 Location: Midlands Posts: 315 |
If you do use heat, you can additionally chill the drain plug with some brake cleaner or something similar. Maybe put a short tube around it, something like a roll of tape to limit the chilling going onto the case.
21st Nov 2023 5:23pm |
pistonfields Member Since: 29 Mar 2022 Location: Zurich Posts: 72 |
Regarding the use of heat: if it has been done properly then thread sealant like Loctite 577 has been used. This can sometimes be rather hard to break that loose. Those thread sealants will decay at 250°C. That's no problem for the alloy, as long as you use a controlled heat source like a heat gun with temperature setting. That way you won't do any damage.
If you use a simple propane torch just heat the bolt for a short amount of time, and only the bolt. That should do the trick. The alloy is quite thick and it'll take some time for it to get too hot. Just avoid any localized heat on the alloy itself and concentrate the flame on the torch. It won't take long. |
22nd Nov 2023 9:02am |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3410 |
I would probably just fill 2.3liters of oil from some other location, and unless there is a leak that requires constant top ups, it would be fine for many years. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
22nd Nov 2023 9:56am |
