![]() | Home > My Defender > 110 CSW Td5 |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2109 ![]() ![]() ![]() |
You’re doing a grand job.
I appreciate that there has been lots to do but it’ll be sorted properly once you’ve finished ‘the list’ and you’ll know every inch of it inside and out, and you’ll know things are done right 👍 I hope you all enjoyed Bala 👌 |
Chriswb84 Member Since: 16 Sep 2023 Location: North West Posts: 22 ![]() ![]() ![]() |
Yeah cheers, its my first post and just wanted to start somewhere really on here. I will keep adding as I go along.
Bala is good, although it was busy when we went and I didn't take anything to use on the Lake although it was just for the night and a bit of a shake down. |
All good stuff 👍
This is a great forum for sharing and learning. Forgot to say earlier - nice Defender! |
jaygti Member Since: 04 Nov 2012 Location: essex Posts: 387 ![]() ![]() ![]() |
Looks Good👍🏻
What does your wife think, now you’ve got it? 2002 td5 90 county hardtop |
She loves driving it, usually try's to grab the keys if were going anywhere in it before I get chance. Although not as mechanically sympathetic so I tend to just listen for the next area to sort.
The Defender is semi retired, as we both work from home and have another car so its not used daily. |
Quite a lot of Defenders are semi-retired and did so at a very young age 👍
I must be doing something (a lot) wrong! |
Barneyboy Member Since: 19 Nov 2014 Location: Exmoor Posts: 1627 ![]() ![]() ![]() |
Hi, that’s looking good, you have made great progress with your Defender, Bala is lovely but does get very busy in the summer, we visit regularly staying at my sisters about a mile or so from Llanuwchllyn it’s a beautiful part of the country and love the low flying Jets coming down through the valley, keep up the great work
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10867 ![]() ![]() |
Welcome with a nice 110 and it's getting better every time you sort out the next job
Thanks for the kind messages folks
Bit of an update, I did some more work on the Defender. Replaced the 2nd row upstand which had some big holes in the back from the corrosion. Thankfully the cross member was in really good condition, and I wonder if it's been replaced at some point.
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Replacement YRM painted and fitted... ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge I then found a post on here of someone fitting VW Touran seats, https://www.defender2.net/forum/topic75593.html I found a set for £150 on eBay including the mounting bracket. Drove to Manchester to collect and installed them this week. Not sure if it's worth much of a write up but I took apart the old seat bench, welded up extensions on the end as they curved up then welded and bolted the base. The front hooks on the seats I used M8 U bolts that I bolted to the seat frame. I also removed the integrated seat buckles on the Touran seats and used the original land rover seat belts. ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge They still retain their ability to fold and be revived and I can once removed two nurses and bolts for the seat frame down and out the way. I just need some black leather seat covers so they will match the front seats when I recover them. |
You’ve done a smashing job there 👍
I wasn’t even aware this was a possible upgrade. Looks like they were made for a Defender. ![]() |
Those seats are great, they fold flat and the middle one can be used as a little table when it's folder down. They hinge forward and easily unclip so can be taken out and because I used the original frame that can be folder up too. The frame is substantial steel tube so it was easy to weld without blowing holes through it but I'm out of practice so I spent a bit of time grinding them all back, checking joint penetration and tidying it up.
I will probably take it out, maybe shorten the front supports so it's about 300mm lower as they are quite high up which reduces head height, also re paint the frame but for now as I want to get round and finish the majority of jobs I can go back round and smarten it all up. I'm planning on taking the caravan to France next year so want the bulk of the jobs list whittled down. Next is removing and painting all the brackets under the rear wheel arches and just isolating the steel from the alu plus install the Glen Lewis rear arch shields. Try to keep the majority of crud from that new upstand panel. |
Super job
So I thought I added this already but must have missed it off somehow. Anyway the caravan is stored round the corner from our house. Unfortunately the battery no longer holds charge, and got red hot the last time we used the van so had to remove it ready to be replaced.
The battery is rather heavy and its a bit of a walk to the caravan, so had to sub contract the job. Anyway a few pictures, with the defender playing its part in the collection and delivery. ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
