![]() | Home > General & Technical (L663) > Retrofitting premium interior lighting to D90 |
ckamps Member Since: 04 Jul 2023 Location: Oregon Posts: 45 ![]() ![]() |
Are the wiring harnesses for premium - aka ambient - interior lighting already in place for 2020-2023 Defenders that don’t have the feature?
Dashboard premium/ambient lights Simon from PowerfulUK has shown that at least on one of his Defenders, the wiring harness is already in place for at least the long dash section of premium/ambient lighting. I assume that the two short sections of the dash also have the unused connectors in place. See 5:48 in: ?si= Door lights: handle and door pocket Do the door lights - both the door handle and door storage pocket areas - have the compatible wiring harness in place? Extending to foot wells Based on the Vulkan Automotive video demonstrating installation of their ambient lighting extension kit, it appears that there’s no existing compatible harness that addresses the footwells. ?si=iDcL4fof6AhyqEyQ Hunters Prestige retrofit kit also shows an extra wiring harness to address footwells: https://huntersprestige.com/collections/li...ension-kit All encompassing kits on Ebay I’ve see some kits on Ebay that offer premium/ambient interior lighting retrofit options for 2020-2023 Defenders. These kits appear to address lighting for dash, two locations in each door, and footwells. Their product photos also show wiring harnesses included in their kit. Presumably, those harnesses are at least needed for the footwells - as in the case of the Vulkan extension kit - and perhaps for the two lights in each door. Here’s one of several examples from eBay: https://www.ebay.com/itm/284165256815?hash...SwELRgE9fw Why do this? I particularly like the notion of subtle lighting in the long dash area. Being able to change the lighting color overall would also be nice. But I wouldn’t expect to change the color very often. (I know I can swap out existing bulbs with different colors for several of the areas, but those don’t address some of the unlit areas that premium/ambient lighting addresses). 2021 D90 Pangea First Edition 2022 D110 X-Dynamic HSE Eiger Grey |
Down & Dirty Member Since: 15 Sep 2023 Location: Somewhere outback Posts: 74 ![]() ![]() |
Have a read here may help
![]() https://www.defender2.net/forum/topic85281-465.html My 24 HSE X-Dynamic 90 Carpathian Grey |
Defendit.. Member Since: 09 Aug 2020 Location: 's-Hertogenbosch Posts: 439 ![]() ![]() |
Hello Marco,
I'am also working on 'how to' retrofit the ambiance lighting interior option. For the dash long Beam we need: 129976 carrier light guide 129968 wire Interior lighting ( with 1 lamp I suppose) For the Drivers display we need 129966 wire Interior lighting ( included 2 lamps I suppose) 129975 carrier light guide 2 pcs. For the center console we need 129927 wire Interior lighting ( included lamp and carrier I suppose) So the above are 6 pieces For the doors I'am really not sure if you also need to replace the 4 pieces. I've read somewhere to check the connectors if they have 3 wires instead of 2. Anyway 10 pieces from € 55,- / € 59,- makes it almost € 600,- There has to be another way to archive this for less money. No Mud flaps for my 90.! ----------------------------------------- P300S MY21 Keswick Green on air, adv.+ offroad pack, DRL+fog, Dinamica Suedecloth + Ebony headliner/Cross Beam- Many Mods.. |
Paladino Member Since: 07 Dec 2022 Location: Serbia Posts: 30 ![]() |
I am also interested in this retrofit. The leds work on lin-bus. Coding is the easiest part (at least I think so)
Does anyone know the pins on the bcm for a my23? Is it 3 pins for the dash or 6 pins for two areas? Is the centre console a separate connection? The leds can be bought from previous generations land rovers. For the led diffusers, maybe we can use Plexiglas tubes, I used them in the past with great success. ![]() Click image to enlarge ![]() Click image to enlarge |
mmbanf Member Since: 16 Mar 2021 Location: Milano Posts: 174 ![]() ![]() |
hi, I'm talking about a defender 90,
the codes of what you need for the dashboard are: LR129927 LR129966 LR129968 LR129975x2 LR129976 regarding the front doors: LR130014 LR130030 LR130051 LR130123 The lights on the original doors without premium lighting are not good, they have two wires, actually the LED source can be adapted with that of some range rovers that you find used but save little money and have shorter wiring. https://www.ebay.it/itm/266322164214 the center console wiring is isolated, not complete. When you have procured all the material, write in pm, be careful it is a complicated job, in particular it requires dismantling many plastic parts and rewiring some connectors, including a delicate connector on the BCM. So the work requires experience, and patience. There are professionals in the UK who offer it as a service. Marco |
Some useful info below from David at Hunters Prestige. Including an observation about the non-OEM UX you might get with some of the other kits out there. Separately, I obtained an installation doc from one of those suppliers. Sure enough, configuration of the lighting was done via existing buttons on the doors. Seemed kind of odd.
It sounds like Hunters might eventually offer a retrofit kit for DIY for those who can’t travel to their shop. Such a kit - which would presumably include wiring in addition to easy-to-obtain lights and other parts - combined with their existing ambient lighting extension to cover the footwells, might be an interesting combo. The BCM aspect seems like the trickiest part. Beyond all of the trim removal required. 2021 D90 Pangea First Edition 2022 D110 X-Dynamic HSE Eiger Grey |
One thing to note if someone tries to do this on the commercial - the power to the leds comes from the bcm/gwm so new wires will need to be installed.
