![]() | Home > In Car Electronics (L663) > Can the navigation map stay zoomed out ? |
inith5 Member Since: 08 Apr 2023 Location: Bavaria Posts: 29 ![]() ![]() |
I had the same problem..... The first thing I did was turn off the auto zoom in the navigation app settings. To keep the map size, don't zoom with your finger but tap on the outside of the map and +/- appears. If you zoom in or out, it stays that way. 23.5MY Defender 110 D250 HSE
milford59 Member Since: 03 May 2023 Location: Buckinghamshire Posts: 24 ![]() ![]() |
Thank you very much - I will try that
pjeski Member Since: 25 Jul 2023 Location: Michigan Posts: 98 ![]() ![]() |
I have auto zoom off, I’m careful where I touch to zoom, using just the + and -, and still it zooms in (but never back out) when I do things like select a traffic delay, for instance.
chpsk8 Member Since: 26 Sep 2023 Location: Midwest Posts: 41 ![]() ![]() |
Same for me. Once I hit cruising speed the map zooms in to almost a useless level. Be it pivi or apple.
Is there a way to control the map on the drivers binnacle as well? I have the full digital gauge set and when I use Apple Maps it just zooms in and I get to watch the little blue ball bounce up and down since it’s so zoomed in. |
