Home > Td5 > ABS light behaviour for MOT |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3471 |
Have an 2009 Puma in family, and behaves exactly the same. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
15th Nov 2023 12:58pm |
derbywill Member Since: 25 Mar 2010 Location: Derbyshire Posts: 560 |
Sounds as though you've got an MOT tester who doesn't know how certain abs systems work, the light stays on until it reaches a set speed (normally around 7Km/h) so it can check the wheel speed sensors.
This is same in HGV's with ABS (Not later EBS) infact the Wabco system fitted to Defenders is very similar to a HGV system. Years ago in MOT garages there used to be a poster on the wall explaining the ABS light sequence of numerous cars on the road. If the tester isn't having any of it I would ask him to contact the DVSA technical dept. thats what we used to do on the HGV side. Good Luck! Will 2005 90 XS 1954 86'' Series 1 tilt 1968 88” 2A 200tdi 2002 110 Hardtop |
15th Nov 2023 1:22pm |
Intercept Member Since: 27 Feb 2017 Location: Suffolk Posts: 587 |
Thanks all. I just spoke to the DVSA helpline (0300 123 9000) and they can't find any reference in their documentation of this being acceptable ABS light behaviour. They advised to refer the tester to the user manual - page in photo below - and if he still fails it for the ABS light then I can appeal. But if their documentation doesn't mention this behaviour as OK then I'd expect my appeal to fail too... They've also asked me to email mot@dvsa.gov.uk to get them to investigate. So far my tester hasn't failed it, but I can see via the tracker that the vehicle hasn't moved since I parked it this morning.
Click image to enlarge |
15th Nov 2023 1:50pm |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2238 |
Testers manual also does not say that the lamp has to extinguish after any kind of delay:
https://www.gov.uk/guidance/mot-inspection...s/1-brakes 02' 110 TD5 Double Cab Rebuild Thread |
15th Nov 2023 2:13pm |
Chicken Drumstick Member Since: 17 Aug 2020 Location: Near MK Posts: 785 |
To be honest I'd be taking stronger action. A vehicle that is type approved and working as intended cannot be the cause of an MoT failure. It isn't as if Land Rover vehicles are rare in the UK either..... so it will be well established this is how this functions. If this wasn't true, then pretty much every Land Rover from the mid 1990s onwards would have a permanently failed MoT and probably a whole host of other vehicles, as I suspect the ABS check physically needs the wheels to rotate in order to complete its check. Ultimately I'd consider using a different garage. Not as if there is a shortage of MoT stations. If they fail it on this I would be seeking compensation for potentially daming the resale value due to having an incorrect MoT history. Basically I'd be bloody annoyed and would quite happily vocalise it to the MoT place. |
15th Nov 2023 2:23pm |
Crisis averted - PASS now issued
But I will be following up with DVSA to request that their guidance for testers is updated to include advice about such systems. Not holding my breath for anything to change, but it's worth a try... Thanks for the advice and comments. |
15th Nov 2023 2:49pm |
cee-b Member Since: 25 Jan 2018 Location: South West Posts: 117 |
Good on you for taking the trouble to follow up for the benefit of others despite you no longer having a problem
15th Nov 2023 3:33pm |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2109 |
It isn’t uncommon for MOT Testers to apply their own interpretations or subjective perspectives to the ‘rule book.’
I’ve had ‘that ABS warning lamp conversation’ with my garage in the past, but they were fine and accepted it. As others have said, if that is the factory ‘as built’ specification, then they are in difficult territory. Of course I did have the situation last year when my Defender failed because the ABS lamp wouldn’t extinguish and I launched into ‘here we go again’ and got quite ‘arsy’ only to be calmed down and told that it was permanently on even above the factory threshold (as above) - and then I had to apologise and spend £££ on a new ABS modulator |
15th Nov 2023 7:34pm |
DVSA have sent a prompt email reply, which I've attached below because it may be useful for others faced with this situation:
16th Nov 2023 9:48am |
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1121 |
This is a very sensible reply and I am sure whoever finds themselves in this situation will find a way out with some effort, dedication and support from common sense people.
The achilles heel is in the "testers are expected to use their knowledge, experience and information available" |
16th Nov 2023 9:55am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17559 |
What exactly are you complaining about? You cannot carry out a decelerometer test without exceeding the speed at which the light goes out, so your tester's reply is entirely in order. Storm in a teacup, methinks. |
16th Nov 2023 10:55am |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6634 |
I'm impressed DVSA got back to you 1988 90 Td5 NAS soft top
2015 D90 XS SW |
16th Nov 2023 11:56am |
