![]() | Home > General & Technical (L663) > Enabling miles per hour on a MY23.5 L663 issued in kph only |
Al B Member Since: 13 Nov 2023 Location: London Posts: 7 ![]() ![]() |
Hi all, new member here. I’ve just moved from Oz to the UK (for the weather…) and I’ve imported my Defender X MY 23.5. It’s going through legalisation at the moment. One (very) mundane item (compared to some of the cool things in this forum) is we are having trouble swapping over / adding miles per hour units to the speedometer. The car was only issued in kilometres per hour and the vehicle settings via the touch screen doesn’t have the option to use miles per hour. I’ve trawled through the internet and found the link below but I think the MY23.5 is different to what this site contains.
https://sx-tool.com/new-jlr-ccf-tools-4-9-...2017-2023/ So I’m wondering if anyone here can advise on what I require to access my car configuration file and make the changes so I can get my car to its legalisation test and on the road. Looking through the link above for the pre 23.5 files, there looks to be an option where I can add miles per hour as a secondary unit (as well as swap to solely mph). Btw: I tried to get JLR to do this but they weren’t in a position to do it (spec changes aren’t supported, but you guys are probably aware of this). Any recommendations / advice is greatly appreciated. Cheers Al |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6638 ![]() ![]() ![]() |
Moved
Moo Member Since: 01 Oct 2021 Location: UK Posts: 1439 ![]() ![]() |
When I travel in Europe I change everything to KPH via Pivi so I presume you can do i5 the other way round. Eiger Grey MY23 D250 SE with bits. Known as Noddy.
Tim in Scotland Member Since: 23 May 2007 Location: The Land that time forgot Posts: 3753 ![]() ![]() |
According to the IGuide the ablity to change speedo unit is market specific, so as the original market was a kmph market you may not be able to change it without a replacing software.
![]() Click image to enlarge Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come 2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed! |
Thanks all.
I saw the speedometer section in the iGuide so I am (dangerously) assuming the car configuration file can be accessed to make the change there. My understanding is that the MY 23.5 is coded differently to those prior hence wondering if anyone has accessed the CCF in a MY23.5 model. I'll keep digging around. Cheers Al |
Thanks for this Screbble - much appreciated. |
Thanks Martin |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5068 ![]() ![]() ![]() |
In the past, you used to go in and could change the market and that would give different features, i assume that is still the case You will probably struggle with a dealer doing it - so you will either need some like lr retrofits or an independent with a good system or maybe try IDD tool Mike |
Thanks Mike, a dealer has already knocked me back! I've got a few enquiries out in the ether but I hadn't tried LR Retrofits so thanks for the heads up.
I've also asked the GAP team on whether their tools work with a MY23.5 so hopefully I can make progress somewhere along the line. Cheers Al |
DefenderMidlands Member Since: 08 Mar 2023 Location: West Midlands Posts: 241 ![]() ![]() |
The jet pro software lists miles to km. whether you can do it the other way round I’m not sure. Script 103
![]() Click image to enlarge MY23 D250 Defender 110 X-Dynamic SE, Carpathian Grey, 7 Seat, Electric Towbar |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2943 ![]() ![]() |
How bizarre that you can't change kmh to mph
Is it some legislation in Australia? Every modern car l've driven has the option to read in either mph or kmh in the menu. |
I think it's more a case of we don't use MPH in Aus (plus there aren't too many crazy people like me who ship their cars around the globe - I was going to lose too much on it for my liking if I sold it). It might be that regs in Aus is the reason - you'd think JLR would prefer not to have someone spending time disengaging MPH from the configuration if they didn't have to.
Cheers Al |
Thanks Aquascape - I'll take a look at the jet pro software. |
Rather madly, dealers arent allowed to do anything with the car, other than things like activating tow bars - they can access everything but arent allowed to do anything not sanctioned by JLR Mike |
