Home > Maintenance & Modifications > Penman trailer brake problem
Page 2 of 2 <12
TexasRover
Just out of interest, are these trailers rated to more than 750kg that they need a brake, or is it just for driving safety and pleasure? I have had 750kg rated trailers with run-up brakes (conventional drum - cable) and especially on a drum braked Series that is nice.
Here in France (Europe) the rules are well and truly f&cked up where for registration and insurance reasons people buy (large) trailers (down) rated to 750kg without the need for brakes (cheaper) to then overload them habitually (how does the average person know) obviously causing a dangerous situation.
Post #1011067 13th Oct 2023 7:06am
LandymanStefan
England 2001 Defender 90 Td5 SW Epsom Green
They’re around 650kg unladen with a load rating of around 1100. So the max weight in theory would be 1750kg and I’m sure most would agree you’d want brakes with that amount of weight behind you. They’re also built heavily enough that I would imagine they can cope with a lot more weight. Coupled with the idea they may be used in abnormal/extreme conditions I can see why they’ve got such a serious set of brakes.
Post #1011091 13th Oct 2023 10:39am
The ULW of a GS Penman is 620kg and the payload is 1130kg, resulting in a gross weight of 1750kg.
So yes, they are required by law to have brakes.
Post #1011098 13th Oct 2023 11:03am
Bigwatty
United Kingdom 2000 Defender 110 Td5 CSW Venetian Red
Penman master brake cylinder
John,
Sorry but I can't pm you as I've only just joined the forum.
Can you tell me where you got a master cylinder for your penman brakes?
I've managed to damage the reservoir on mine and could do with finding a replacement. If you've still got your old one and the reservoir is intact I'd be happy to make you an offer!
Chris
Post #1015035 13th Nov 2023 11:40pm
GreenGiant
hello all.
this is very interesting reading.
i have a penman trailer as well but my handbrake is not working on one side.
i am currently in poland and need as much information onm the actual brake caliper.
is this a standard caliper which i could replace with a new one? has anyone got details what the make and model of the caliper are? i heard its from citroen.
thx
Post #1044800 4th Sep 2024 5:33pm
LandymanStefan
Hello!
Yes they are standard Citroen xantia brake calipers.
There are a few variations of the caliber as I found when trying to buy the correct seals for them, I ended up buying a few different seal sets and sending the ones back which weren’t required.
Have you checked the cable and operation of trying to move the hand brake lever on the caliper manually?
Post #1044802 4th Sep 2024 5:42pm
GreenGiant
hi . thanks for the quick reply
the cables move freely.
The little black leaver on the drivers side caliper has absolutly no resistance.
It dosent do anything. passenger side seems to work.
do you remember the models of xatia calipers which maybe suitable?
i may be able to find one here or buy a new replacement one.
thanks
GG
Post #1044804 4th Sep 2024 5:53pm
Page 2 of 2 <12
