Home > In Car Electronics > Trailer Indicator Warning Light
Penfold_6290
United Kingdom 2002 Defender 110 Td5 CSW Epsom Green
Hi folks, my Td5 Defender has an irritating problem. The trailer indicator warning light does not operate as it should - with or without the trailer(s) hitched on the trailer indicator light illuminates once when the indicator is first operated but doesn’t flash in time with the indicators when the trailer is on. Standard bulbs, no LEDs, same issue with two of my own and one borrowed trailer. It has worked correctly in the past,but very sporadically and not for a while.
The trailer indicator light flashes with the hazards on which I believe is supposed to happen. Do I go straight to the flasher relay and do some swapnostics?
Thanks, Martin.
Post #1014833 11th Nov 2023 8:45pm
