Home > Technical > Max width on a Wolf Rim
Grenadier
Hola, Salut, Yo.
What's the max width that I can put on a genuine Wolf rim? More specifically I've been offered some Nokian Winter tyres in a 245. Will that work?
Ta Thumbs Up Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #1014572 9th Nov 2023 6:55pm
A 245 will be no problem. I used to have a set of 255/85 KM3s on Wolfs and they were fine.
Post #1014573 9th Nov 2023 6:58pm
geobloke
Folks say 265 is about the widest you can put on, but they do look a little oddly wide at the top and skinny at the rim. Tyre shops say 235 or 7.50 is the idea size.
Make sure you give those rims a good spray of something protective to keep the road salt out of the groove between the rim and the backing plate. Big rust trap.
Post #1014581 9th Nov 2023 7:43pm
MarkBrown
Wales 1983 Defender 110 Other HT Auto Keswick Green
Mine have 255 85 16's, no problems. When I refurbished my wheels I rust killed then seam sealed the join. Followed by paint. No rust at the join then!
Post #1014621 9th Nov 2023 10:06pm
Grenadier
Thank you all.
The tyres are:
Nokian WR Suv 3
245/70/R16
111H
100€ for 4, 40% usage. Just need them to get me through winter as I'm hanging on desperately for the KO3 release..... Monsieur Le Grenadier
Post #1014675 10th Nov 2023 10:55am
Chicken Drumstick
Should be fine.
The US BFG site is handy as they list lots of sizes and rim specs. Just scroll to the bottom where it says view all sizes and find the size you are interested in.
https://www.bfgoodrichtires.com/auto/tires...yreSize=16
Post #1014685 10th Nov 2023 11:56am
Grenadier
Just found another set of the following at half price.
2021. Under 20% usage.
Nokian Rotiiva 225/70R16 107T XL
Too small for a 110? Monsieur Le Grenadier
Post #1014690 10th Nov 2023 12:32pm
Yes, too small, it will look ridiculous!
Post #1014695 10th Nov 2023 1:56pm
jst
i had the same.
you want a 235.85s really. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1014702 10th Nov 2023 2:28pm
lolo
Switzerland 2008 Defender 110 Puma 2.4 CSW Keswick Green
Hello Mark, can you descibe how and with what you have seam sealed the join?
Thank you!
Lolo
Post #1048727 15th Oct 2024 10:49am
MarkBrown
The wheels were in good condition to start with, so following sanding I brushed on some rust converter, then used PU sealer ( when dry ) to fill the join, then sprayed them. This then keeps the water out. It’s the stuff they use to stick car body panels together, I bought mine on eBay, there’s several brands and colours, but as far as I can tell it’s all similar. One tube for two wheels should be plenty.
Post #1048761 15th Oct 2024 4:15pm
lolo
Thank you Mark 👍🏻
Post #1048800 15th Oct 2024 8:47pm
