Home > In Car Electronics > Heated seat wiring
excossack
Heated seat wiring
Currently have heated seats fitted (Mud stuff wiring loom and switches) these are fed via a voltage sensing device the switches the main relay. The voltage sensing device has started to play up.
I went for the voltage sensing device to stop the seats being left on if the ignition is off.
Before I replace I was wondering is there a better way of wiring in the heated seat wiring? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #1014398 8th Nov 2023 3:03pm
A regular relay switched by an ignition live? Darren
Post #1014402 8th Nov 2023 3:17pm
excossack
That is probably the way to go. But which feed? Not the radio feed 1999 Defender TD5 110
Regards
John M0VAZ
Post #1014405 8th Nov 2023 3:43pm
Martin
Site Admin
Heated rear window switch input?
This is the one that the LR 13 pin electrics kit taps into.
Basically any of the white/green behind the dashboard would do to trigger a relay.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1014407 8th Nov 2023 3:45pm
excossack
cheers Martin. Looks like a job for the weekend to rewire a wee bit 1999 Defender TD5 110
Regards
John M0VAZ
Post #1014408 8th Nov 2023 3:48pm
