Home > General & Technical (L663) > Activating ACC, ATPC, TR2 Auto, Park Assist, wheel size etc
Page 3 of 11 <123 4 ... 91011>
Nicofender
Germany
I also tried today to activate ACC on a MY23. Did it like you guys said but I always get the Brake error. Tried to write the backup file, it seems the CCF is back to normal but the error persists. Also if I try to clear DTC it doesn’t seem to do anything…
Post #1014390 8th Nov 2023 2:33pm
DefenderMidlands
Script 18 I think is the correct one for ACC.
After running script go to the first tab and select DADC from the CCF to allow it to relearn the script else the errors will remain. Also restart the gateway.
Forzahog on here might be able to help more as he had made it work, I already have ACC so couldn't try it. Alternatively WhatsApp tech support at autosvs
 MY23 D250 Defender 110 X-Dynamic SE, Carpathian Grey, 7 Seat, Electric Towbar
Post #1014392 8th Nov 2023 2:39pm
DefenderMidlands
After changing CCF files or updating scripts to clear brake error YOU HAVE TO go to Main menu, select DADC module from drop down list, then click on CCF memory and select 'DADC-DriverAssistanceDomainController Learn vehicle configuration (as in the picture) and do the same with the IGM module relearn both of them (picture shown below)
After check DTC, clear DTC on both modules, lock car and leave to sleep for 10 minutes and it will work (this info is from GARY at autosvs)
Post #1014396 8th Nov 2023 2:56pm
forzahog
United States 2016 Defender 110 Other Works V8 Auto Fuji White
Script 17 is what they told me to use and that worked for me.
My steps...
Connect the obd cable
Ignition On
Start the app
Read the ccf
Run the Script (17 in my case)
Push the ccf
Select DADC from the ccf memory button.
Finished
I think I then cycled the ignition and then started the rover. After that I could see the icon change when I hit the "Lim" button on the steering wheel. 20MY Defender 110 Fuji White
Post #1014397 8th Nov 2023 3:03pm
EataPeach4923
Where’s the ccf memory button?
Post #1014399 8th Nov 2023 3:11pm
forzahog
On the first tab.
You can see it on that last screenshot from aquascape. 20MY Defender 110 Fuji White
Post #1014400 8th Nov 2023 3:12pm
DefenderMidlands
Post #1014411 8th Nov 2023 3:55pm
Nicofender
Germany
Awesome guys. Was a 100% user error. Thanks for the picture. I tried script 18 and had a test drive for around a hour and works just fine!
Post #1014414 8th Nov 2023 4:14pm
DefenderMidlands
Glad you have it working. Its not too complicated when you know what to do
A few other scripts to try:-
Script 1 - Remember stop/start memory
Script 2 - Approach unlocking (only for cars without locking fuel cap)
Script 5 - Open rear tailgate from keyfob (wont work with soft close doors)
Script 16 - ATPC, TR2 Auto and Dynamic Mode
Script 18 - ACC (possibly script 17 for some cars newer than 2021)
Script 24 - PIVI Auto parking (maybe needed for park assist, not sure)
Script 34 - Defender 007 logo on startup
Script 35 or 98 - Enable Wifi
Script 37 - 300hp power upgrade for D00/D250 (not sure if this works)
Script 115 - Parking Assist (I think this is the script needed to enable park assist)
These are all trial, the may work on your car, may not, different cars can be different requirements.
Can also of course manually change the CCF files as in the sticky and GAP tool lists MY23 D250 Defender 110 X-Dynamic SE, Carpathian Grey, 7 Seat, Electric Towbar
Post #1014416 8th Nov 2023 4:44pm
forzahog
It's a little confusing now that I look at your list. I don't have some of those and the script numbers are different. For example, 115 Parking Assist isn't even on my list. Any idea what values that is changing? 20MY Defender 110 Fuji White
Post #1014445 8th Nov 2023 7:39pm
DefenderMidlands
I think they are vin specific. 115 on mine isn’t actually called park assist. It is called Vertical and horizontal parking system suitable for front and rear 10-12 probes.
I don’t think there is anyway to see what the scripts change. Only way is to look at before and after CCF’s and compare them. MY23 D250 Defender 110 X-Dynamic SE, Carpathian Grey, 7 Seat, Electric Towbar
Post #1014465 8th Nov 2023 9:22pm
DefenderMidlands
Post #1014468 8th Nov 2023 9:28pm
EataPeach4923
Trying now
Post #1014491 9th Nov 2023 4:25am
DefenderMidlands
According to autosvs this is the script needed for park assist
Post #1014493 9th Nov 2023 6:37am
EataPeach4923
They got me sorted and all is working well. No luck with the park assist. I see the icon come up but when I click on it it just stays on a blank screen. Oh well.
Post #1014496 9th Nov 2023 6:42am
