![]() | Home > General & Technical (L663) > How do I turn OFF the door mirror anti-glare |
J77 Member Since: 04 Nov 2019 Location: Fife Posts: 3453 ![]() ![]() |
No way to turn it off 24MY 90 D250 HSE, Tasman Blue
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3016 ![]() ![]() |
Why would you want to turn it off?
Mine only does it if if it's very bright such as reversing into the sunlight |
LR Nuts Member Since: 10 Aug 2022 Location: UK Posts: 1261 ![]() ![]() |
Travelling at mid-winter Dawn and Dusk. I believe my vision is obscured, when dark coloured cars are around me.
I don't want to turn them off permanently, just during certain hours. |
Moo Member Since: 01 Oct 2021 Location: UK Posts: 1468 ![]() ![]() |
What is this? How do I know if I have it?
I'll get some photos
XplusYplusZ Member Since: 16 Aug 2021 Location: UK Posts: 524 ![]() |
I think most defenders have it - you can see it best on the driver's wingmirror, it automatically darkens most of the mirror to reduce glare from headlights behind. You can still see a small outer layer of non-dimmed glass which helps you know it's switched on. I think you can choose auto dim on/off in the menus, but i could be wrong. ![]() |
well after a lot of faff, I have finally got the 3 mirror set to turn off the 'LCD look'. as shown in right hand photo above.
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2719 ![]() ![]() |
Care to share how you did it?
I must admit .......... I don't really know.
1. I turned ignition on WITHOUT starting engine. Selected headlamps to 'AUTO' 2. I moved centre sun visor to up position. 3. I prayed. Now which one of above worked, or any permutation ????? |
![]() Click image to enlarge found this in the eManual. |
Buz1500 Member Since: 07 Jul 2020 Location: Cumbria Posts: 150 ![]() ![]() |
If you lower the centre sun visor this usually activates the dimming procedure. It always does in my car.
I rarely use the centre visor so I never found it an issue to be honest. You could say it was a benefit, allowing you to activate the function when desired when the automated process isn’t kicking in. |
I did a RTN journey to London today.
And YES the centre sun visor does turn on and off the 'LCD' in all three mirrors. If only people knew that !! as for auto turn on-off still haven't worked that out ?? bearing in mind it takes around 8-10 secs to activate. |
wrong thread
