Home > General & Technical (L663) > Activating ACC, ATPC, TR2 Auto, Park Assist, wheel size etc |
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1420 |
I did actually look into this a while ago but they guy I spoke to quoted £2K for the complete kit, that's when I decided to stick with IID tool and wait for them to sort things. Although the only thing I would like to do now is activate the parking but I'm not in a hurry for that
ETA Just remembered he also said it would only work on a Windows PC, which I don't have Cheers Ian -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
5th Nov 2023 7:57pm |
DefenderMidlands Member Since: 08 Mar 2023 Location: West Midlands Posts: 227 |
They do offer a permanent single bin licence for about £1500 now I think but offer the full working version for 72hrs for $99 which is what I used. Can buy as many of those as you need. It’s fairly cheap but a bit inconvenient. Just need to know what changes you want to make. I think park assist can be done and also if you change wheel size MY23 D250 Defender 110 X-Dynamic SE, Carpathian Grey, 7 Seat, Electric Towbar
5th Nov 2023 8:26pm |
Oh I can see the attraction of it, the person I spoke to never mentioned the £99 option which as you say, if you know what you want to do could be a solution Cheers Ian
5th Nov 2023 9:21pm |
EataPeach4923 Member Since: 07 Jun 2023 Location: USA Posts: 17 |
Did you need anything else beside the 72hrs software license and Enet cable? I have a MacBook, but wondering if this would work with a windows emulator. I’m looking my to activate ACC and dynamic mode. Wonder if this one can activate the air quality screen as well. |
6th Nov 2023 5:12am |
I think the software works on Mac too. Pretty sure there was a lwindoed or max version. I just needed the enet cable then bought the 1 bin 72hr trial $99. Might be best to message them through their website autosvs.com to check about mac software. Gary Wai the CEO was quite helpful
I received an email with the software link almost straight away. Downloaded the software. Activated it with the code they gave me for 1 vin for 72hrs. Connected cable to car. Changed ccf files. Sent updates to car. Cleared dtc in DADC module and all was done. 15 mins Click image to enlarge Click image to enlarge MY23 D250 Defender 110 X-Dynamic SE, Carpathian Grey, 7 Seat, Electric Towbar |
6th Nov 2023 6:14am |
Thank you very much for the info! Cables ordered, will purchase software when they arrive. Have you had any luck activating park assist? I read somewhere that the Defender doesn’t have as many cameras as other JLR vehicles with park assist so I would be pleasantly surprised if it worked.
6th Nov 2023 4:36pm |
Cables? You only need 1 cable. Hardest part was installing the software as my windows security software was blocking it for some reason. After that activating atpc, tr auto etc was easy. I ran out of time with my 72hrs to try park assist but it should work. Someone on this forum managed to make it fully work with the gap tool but couldn’t clear the brake error which you can do with this tool. Park assist needs 360 camera and acc to work. MY23 D250 Defender 110 X-Dynamic SE, Carpathian Grey, 7 Seat, Electric Towbar
6th Nov 2023 5:48pm |
Have to buy an Ethernet to USB C adapter since MacBooks don’t come with the input.Cant wait to try this out.
6th Nov 2023 6:22pm |
forzahog Member Since: 03 Nov 2022 Location: Fayetteville Posts: 66 |
Did you have to give the Enet cable a static IP or just plug it in and let it use DHCP? 20MY Defender 110 Fuji White
6th Nov 2023 7:53pm |
No I just plugged it into my windows laptop and it worked fine MY23 D250 Defender 110 X-Dynamic SE, Carpathian Grey, 7 Seat, Electric Towbar
6th Nov 2023 7:59pm |
Ok, great. I'll try this software out. Thanks 20MY Defender 110 Fuji White
6th Nov 2023 8:01pm |
Where was your login key after the download? 20MY Defender 110 Fuji White
6th Nov 2023 8:51pm |
In the read me file on the download MY23 D250 Defender 110 X-Dynamic SE, Carpathian Grey, 7 Seat, Electric Towbar
6th Nov 2023 8:58pm |
My download doesn't have a license key. It just says enter the key you get from us. I'll just reach out to them and see what they say. I don't have the warmest of feelings having to disable the AV just to install it. 20MY Defender 110 Fuji White
6th Nov 2023 9:02pm |
