![]() | Home > Td5 > TD5 Speedo and ODO not working |
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1236 ![]() ![]() ![]() |
Did you remove the instrument cluster and checked the connection at the back? Possibly it is loose or removed on purpose to avoid clocking additional miles. It being blank means it is either broken or not receiving 12v
The system is quite simple with the odometer receiving a pulse and recording the miles. The ECU does get the speed signal (for cruise control etc) but does not record any mileage. The speed signal is recorded through a sensor at the rear output shaft of the transfer box (where the drum handbrake is) |
