Home > Puma (Tdci) > 2.2 stopped and won't restart.
psimpson7
Australia 2014 Defender 90 Puma 2.2 XS CSW Loire Blue
Hi all,
I need some help with an issue with our 2014 2.2 90.
I am based in Australia so it doesn't have a dpf. For reference we bought it new. It has done 175k km. It has never had any remap etc and has been serviced every 10k km since new.
Driving along a few weeks ago and it stopped and wouldn't restart. Got it towed home. It attempts to start and occasionally will run for a few seconds roughly and then stops again. It's very smokey when it does half start.
I've done a compression test and I don't think it's holed a piston which was my initial concern. Turbo seems fine. It does have fuel at the rail. No codes on the ECU I can see using a generic code reader.
Anyone had similar? I wonder if it's fuel pump / pressure related.
Thanks! 2001 90 HT 6.0LS/6spdAuto.
2003 90 td5 soft top.
2014 90 XS SW 2.2.
Post #1005189 23rd Aug 2023 11:13am
Dinnu
The VCV perhaps? But not that common on 2.2s. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1005207 23rd Aug 2023 2:51pm
MK
As said, the VCV. Also check if the fuel pump works. I guess it should spit fuel through the fuel pipe located just before goes into the HP pump. Puma 110" SW
Post #1005208 23rd Aug 2023 3:09pm
psimpson7
Cheers will try next and update if it helps 2001 90 HT 6.0LS/6spdAuto.
2014 90 XS SW 2.2.
Post #1005341 24th Aug 2023 7:59pm
Howard
United Kingdom 2012 Defender 110 Puma 2.2 PU Alpine White
I thought the VCV is only fitted to the 2.4. The 2.2 has a different system I.e a lift pump in the fuel tank.
Post #1013439 31st Oct 2023 11:08pm
Ianh
The 2.2 does have a VCV, however i’ve not read any posts on one failing. Unlike the 2.4 where it is a common issue.
That’s not to say in this instance it’s not the VCV, but faults seem to be vary rare. Noting that the absence of any DTC’s tends to point to the VCV.
Have you replaced the fuel filter recently? Have you drained the fuel filter to see if there is any water in it ?
When you turn the ignition to 2 , but not start the engine, can you hear the pump in the tank circulating fuel ?
Worth checking the fuel pump relay and fuse in the seatbox https://www.lrworkshop.com/wiring-diagram/...fuel-lines
NB- if you do decide to change the VCV here is a great how to for the 2.2 https://www.defender2.net/forum/topic86260.html?highlight=vcv
Post #1013445 1st Nov 2023 1:10am
