![]() | Home > General & Technical (L663) > Defender L663 reliability and durability |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2943 ![]() ![]() |
That is bad. The ZF transmission is well regarded and reliable, seriously bad luck you've had two failures.
My D250 HT is 11 months old and had no issues at all. |
GilesM Member Since: 19 May 2021 Location: East Lothian Posts: 40 ![]() ![]() |
My P400 XS edition will be 2 years old in January, so far 41K trouble free miles, the only time it stopped moving was in the mud run at Billing, but that was more to do with road tyres and my lack of ability.
silent_fury Member Since: 28 Aug 2022 Location: Romania Posts: 23 ![]() ![]() |
So, update on my D300.
I hear a clunking noise on front left suspension, when I use country roads. ![]() On tarmac is quiet. 17000 km ODO. Defender L663 110 D300 // G06 2023 xDrive 4.0i // ex G05 2021 xDrive 4.0i // VW Touareg 7P 2016 // ex G02 2020 2.0D xDrive // ex G30 2017 540D xDrive // ex F26 2017 2.0D xDrive // ex F30 2.0D 2012 // ex F30 2.0D 2014 // ex F25 2015 2.0D xDrive // ex F10 2016 525D xDrive |
Do you have the air suspension or coil springs?
Air suspension.
I'm scared ![]() |
Have you driven off road?
Have a look underneath and see if there's anything that doesn't look right |
Nope, no off road.
Is scheduled for maintenance these days at dealer JLR. I am very curious for what it is. Defender L663 110 D300 // G06 2023 xDrive 4.0i // ex G05 2021 xDrive 4.0i // VW Touareg 7P 2016 // ex G02 2020 2.0D xDrive // ex G30 2017 540D xDrive // ex F26 2017 2.0D xDrive // ex F30 2.0D 2012 // ex F30 2.0D 2014 // ex F25 2015 2.0D xDrive // ex F10 2016 525D xDrive |
DAP2022 Member Since: 16 Feb 2022 Location: Norfolk Posts: 120 ![]() ![]() |
Mine did that - clunk from front
Dealer had to replace both Ft Lower Control Arm - Land-Rover (LR144506) Only on rutted roads Made a big difference to quietness of car on all roads once done Feb 2023 build - ? Faulty components batch |
Mar 2023 built.
Good to know! ![]() |
Update on my D300 - Left Front Lower Control Arm - (LR144506) need to be repaced. Defender L663 110 D300 // G06 2023 xDrive 4.0i // ex G05 2021 xDrive 4.0i // VW Touareg 7P 2016 // ex G02 2020 2.0D xDrive // ex G30 2017 540D xDrive // ex F26 2017 2.0D xDrive // ex F30 2.0D 2012 // ex F30 2.0D 2014 // ex F25 2015 2.0D xDrive // ex F10 2016 525D xDrive
Moo Member Since: 01 Oct 2021 Location: UK Posts: 1439 ![]() ![]() |
Do they have the parts do get you going again quickly? Eiger Grey MY23 D250 SE with bits. Known as Noddy.
Great that you found the fault. Suspension noises can be difficult to pinpoint.
They got my 2 lower control arms within 2 days
Must be faulty batch, |
The parts will be available in 2 weeks max.
Meanwhile, at 17k km, I change the oil & stuff. Everything seems good for now! ![]() |
