![]() | Home > Td5 > Td5 interior light earth - dash warning lights on w/o key |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6653 ![]() ![]() ![]() |
There’s no factory fitted box with all black wires behind the dash soldered into the loom. This is aftermarket, but undoubtedly the cause of your problems.
What colour wires were the black wires to/from the immobiliser unit connected to? What you need to do is restore the wiring back to factory standard. With the colour info I’m sure we can help. ![]() ![]() |
What interior light earth, do you mean the instrument illumination or the roof light?
Which wire (colour) are you earthing to make things work? ![]() ![]() |
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1211 ![]() ![]() ![]() |
It's not overly complicated and you should be able to trace back all the wires surrounding you ignition switch. Looks like you have an issue on how the power is distributed since things are switching on that should not
The other thing to check is that you have ALL the earth ring terminals correctly fitted - including:
* the one which looks like a white/grey connector but has a ring on it, this goes behind the coolant expansion tank. * the one in the seat box near the fuse box front bracket Devices finding a earth path through each other does weird stuff ![]() ![]() ![]() |
Defenderlad224 Member Since: 30 Oct 2023 Location: Yorkshire Posts: 2 ![]() ![]() ![]() |
Thanks for the help so far, pretty well versed with defenders but my owns a 200tdi so not nearly so much gubbins to go at.
The immobiliser is frustrating but I actually think it’s not the cause of the problems what so ever at this stage, it might well become a problem when it turns over and doesn’t fire - but for now that can be an issue for another day. I think martins probably on the right track in that we’ve missed some earths. When i write of the interior light earth there appears to be a black wire with a single spade terminal that goes onto a spade on the interior light back plate (as in the light in the headliner) Forgetting the immobiliser our first thoughts was that the ignition switch was wired wrong - but it seems correct to all photos we have of it prior to disassembly and matches every online image and diagram I can find. So starting again - what earths should I have, around the bulkhead and dash, I’ll find these and make sure everything’s where it should be for starters. The ECU is definitely earthed in the bottom of the box, there are two thick black earths that come out the loom separately at the back of the engine that are earthed to the engine, it’s difficult as three of us have been working on and off over a protracted period so the person who refit something wasn’t necessarily the person who removed it - the potential for things to have been missed is fairly huge! |
