Home > Off Topic > Yorkshire Fog this morning |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2238 |
And conversely, light drizzle on the A1/M1 and every other car has their rear fog lights on 02' 110 TD5 Double Cab Rebuild Thread
27th Oct 2023 5:15pm |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2110 |
I suspect in both cases it’s the same people that don’t bother to use indicators anymore..Oh God I’ve finally become my dad
27th Oct 2023 5:17pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17558 |
Hmm, rear fog lights... One of the most stupid and unnecessary ideas of modern times, probably resulting in more accidents than they have prevented, and misused and misunderstood by more drivers than almost any other feature.
27th Oct 2023 5:31pm |
Mike c Member Since: 11 Aug 2017 Location: Maldon, Essex Posts: 930 |
To be fair when they were made mandatory (early 80s?) tail lights were less visible and there was usually only one rear fog lamp mounted low down so made sense on fast roads/motorways in fog/low visibility conditions.
These days they are high intensity led ( like the headlamps 🙄)and usually two lamps placed higher up, that and the fact drivers are so disconnected from what they are doing in modern vehicles so just leave them on so makes it far worse and creates glare which completely defeats the object! 2004 Defender 90 Td5 CSW 2002 Discovery 2 td5 GS (gone) 1994 Defender 90 300Tdi CSW (gone) |
27th Oct 2023 5:47pm |
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2653 |
Round here some still use their front fog lights thinking they are DRLs.
Those with their rear fog lights on in otherwise clear conditions more often that not don't realise that the extra intensity of the fog light masks the brake lights.. |
27th Oct 2023 6:37pm |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2109 |
Apparently using your indicators isn’t cool 🤪 I still use mine which kind of proves that theory right. I also don’t cut corners. I’m so uncool. |
27th Oct 2023 6:40pm |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10857 |
I'm the same as you Screbble Clayton. 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
27th Oct 2023 7:36pm |
Pickles Member Since: 26 May 2013 Location: Melbourne Posts: 3787 |
We don't get many "Fogs" in Aussie, certainly nothing like the REALLY thick fogs we experienced in Manchester in the 50s, some were so thick you couldn't see a few feet in front of yourself!
27th Oct 2023 9:42pm |
