Home > Maintenance & Modifications > Rear door struts |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5850 |
Cheers. Looks like the door mounting plate sticks out quite a bit, I think the top angle section will clash with the door card 1999 Defender TD5 110
4th Aug 2023 6:43pm |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3420 |
My solution was very similar to the one pictured on page 4 of this post:
https://www.defender2.net/forum/post383925.html My difference was that I fabricated a bracket that bolts in the original 2 holes in the tub (saves drilling the tub), and was such that it protects the gas spring in case heavy stuff moves in the back of the landy. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
4th Aug 2023 8:52pm |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2103 |
I know it’s aesthetically not to everyone’s taste, but I have the Naka version that’s mounted to the top of the door frame. It’s been fitted for years without any issues
Vastly improved both opening and closing the door and can’t imagine life without it now |
5th Aug 2023 1:32pm |
ChrisCSL Member Since: 10 Aug 2019 Location: Berks Posts: 186 |
Happy to confirm that there’s no problem with the door card. All fitted nice and flush Chris |
13th Aug 2023 9:39pm |
Norfolk-n-chance Member Since: 01 Sep 2019 Location: Usually in the garage! Posts: 80 |
I’ve been looking at this one
https://www.lrparts.net/jwp1205-top-mount-...-2016.html It’s got a slow stop. I like the idea that I don’t have to dismantle loads of other stuff to fit it… “a committee is a group of people who individually can do nothing, but as a group decide nothing can be done.” |
13th Aug 2023 11:27pm |
I have ordered a strut from Bison. This fits on the bottom of the door frame and looked less bulky than others. A review to follow once installed. 1999 Defender TD5 110
25th Aug 2023 9:01am |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4700 |
Paddocks have this listed.
https://www.paddockspares.com/catalogsearc...t+defender 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
27th Aug 2023 12:18pm |
peanutbob Member Since: 12 Feb 2009 Location: UK Posts: 293 |
Hi - I’ve just purchased one of these top mounted gas struts. The top 2 grab handles above the rear door need to be removed - anyone know what type of bolts/screws are under the plastic clips? Incidentally, LR Centre sell the same version at £35.00 delivered. Thanks! |
26th Oct 2023 6:14pm |
The grab handles are held on by large ish cross head self tappers (on mine anyway).
Keep them loose until the adjustment is complete. I think the struts may differ between the various offerings in terms of their force. Mine has been excellent over many years of use. |
26th Oct 2023 7:15pm |
Great.many thanks for the advice. At least it will stop the rear door booting me in the posterior when I’m getting the dogs out!
26th Oct 2023 7:43pm |
mcma1 Member Since: 16 Oct 2012 Location: Northern Ireland Posts: 2899 |
I have the mud stuff kit and I don’t like it. It would throw the door open if you don’t stop it. Can these be adjusted at all? Also takes too much effort to close. Andy
2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
4th Mar 2024 8:04am |
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1081 |
The gas springs are extremely common to buy aftermarket in all shapes and sizes (and quality). It wil need a bit of measuring and searching but you should be able to find a replacement with less spring pressure and more dampening. They just clip in so no need to mess with the doorcard or brackets.
4th Mar 2024 8:21am |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4216 |
I’ve got the Mud one and it doesn’t do that. It slows just before it gets to full extension. It can take quite a bit of effort to overcome the strut to close the door when parked up hill though. 2007 110 TDCi Station Wagon XS |
4th Mar 2024 8:48am |
I have never actually let it fully open on its own, always feels like it will damage something! Must try it this morning to double check but a video to compare would be great. Andy
4th Mar 2024 8:51am |
