![]() | Home > Td5 > R380 Gearbox question |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2109 ![]() ![]() ![]() |
Hi, I’m not sure I fully understand your problem/question.
The transfer box and main gearbox are separate and require different oils. Both should have a drain and fill plug. You can use the fill plug hole to check levels and/or you can drain and refill using the correct measurement. I’m interpreting that you have a leak around the transmission area so I would clean the area up and top up both boxes and see if you can identify the source of the leak. Apologies if I have misunderstood your problem. Good luck 👍 |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2238 ![]() ![]() ![]() |
I suspect you are referring to oil in the selector housing on top of the gearbox (item 16 here: https://www.lrworkshop.com/diagrams/land-r...er_53550)?
I have seen this previously myself, there shouldn't actually be any oil in there, just a smear of grease. It probably means that the o-ring on the selector shaft (item 12 here: https://www.lrworkshop.com/diagrams/land-r...fts_53557) could do with replacing but also worth confirming that the gearbox breather is not blocked causing pressure to be forced up through the shifter. Oil sat in there wont be doing any real harm though unless it increases in level and starts to overflow. Steve 02' 110 TD5 Double Cab Rebuild Thread |
Aha that interpretation and explanation makes sense Steve and my response makes none!
doruk1981 Member Since: 15 Aug 2022 Location: Aargau Posts: 100 ![]() ![]() ![]() |
Hi all,
Thabks Steve, I indeed was referring to that area. Got late and i did not take any pics of the spot…now i cleaned it up and will grease it up again.smelled like rotten eggs that further went bad … Somewhat reluctant to crack ip up any further as in spring i’ll replace the whole unit with a winchester unit … But i was surprised to find any “oil” there as it did not have the sign of inlet or outlet in this space Td5 110 Station |
