Home > Modifications & Maintenance (L663) > Lucky 8 Stealth Winch Mount
Page 1 of 3 123>
ODPA
United States
Decided this weekend was finally time to do the winch mount project. Had all the bits I wanted on hand as I wanted to do a few things while I had the front all apart. Plan was to install the stealth winch pack with TerraFirma 12k winch. Paint silver bumper and body color grill flat black to match hood and other plastic bumper and wheel arch parts. Run a wire harness for the future mounting of a Baja Design S8 light bar which will be mounted in conjunction with bull bar install. Cut an access hole for front recovery loop and finally install the LED grill light. Everything went smooth and the Luck 8 products are very nice. Only issues I came across was the bolts included with the winch to mount the fairlead were too short for the Factor 55 aluminum fairlead so I had to source some longer ones and the wires for the LED grill were too short to run all the way to the fuse box. Neither huge deals as with a little modification all is well. I am very happy with how it turned out. Was not as bad of a project as I thought it would be.
Some pictures of the project.
Post #1012067 22nd Oct 2023 3:34am
Bobtailkev
United Kingdom 2011 Defender 110 Puma 2.4 USW Buckingham Blue
That’s very neat and tidy Thumbs Up
Post #1012072 22nd Oct 2023 8:24am
ODPA
United States
Thanks. I am happy with the results.
Post #1012114 22nd Oct 2023 3:12pm
Hairy Dan
United Kingdom 1998 Defender 90 V8 Petrol 50th Auto Chawton White
Looks great Thumbs Up Cheers Ian
22MY Defender 110 D200 SE, Fuji White.
Kielder 4x4 Safari
Instagram @defender_v8
Post #1012122 22nd Oct 2023 3:56pm
ODPA
United States
Thanks Ian.
Post #1012125 22nd Oct 2023 4:44pm
Moo
Ukraine
Looks good and your slowly managing to hide it. Laughing Thumbs Up Eiger Grey MY23 D250 SE with bits. Known as Noddy.
Post #1012151 22nd Oct 2023 9:15pm
ODPA
United States
Haha I know many don’t like the color. Me personally I really like it. I like the look of the paint scheme on the x which has been the motivation for the change. That and I don’t like the silver bumpers. Will paint the back one when I add tow hooks and the rear ladder. No more paint changes after that.
Post #1012160 22nd Oct 2023 10:00pm
Cheshire110
Nice job!
I’ve just bitten the bullet and ordered a kit to be shipped over here to the UK for my V8 Mr. Green
The Lucky8 video seemed really helpful - think I’ll tackle it myself (probably with some help!) Cheers, David
Post #1013658 2nd Nov 2023 4:05pm
ODPA
United States
I think you will be surprised at how easy it is. Just take your time in the areas where the video says be careful and all will be fine. Only issue post installation I have had is my bumper geometry is slightly different. You don’t notice looking at it but it now rubs with my slightly larger tires where it did not before. I believe it because of how snug the bottom of the bumper opening presses against the winch tray causing flex that was not there before. I plan to trim it down to relieve some of that and see if my issue goes away. If not then I will trim the wheel well side bottom of the bumper to clear.
Post #1013788 3rd Nov 2023 3:34pm
Cheshire110
Thanks!
That’s encouraging.
Looking forward to it! Cheers, David
Post #1013789 3rd Nov 2023 3:40pm
ODPA
United States
Problem solved. In the video it says to leave the bottom of the bumper opening tight on the winch tray. I cut it based on the video and instruction specification but this caused too much flex in the bumper resulting in a minor clearance change in the wheel well. Trimming that area and then pulling out on the bottom of the bumper when tightening the four attachment screws on the bottom returned the clearance to normal. Running stock tires I doubt this would be an issue but if not be aware some trimming may and adjustment may be needed to make sure clearances are good.
Post #1013967 4th Nov 2023 11:46pm
Cheshire110
Job done!
As has been said above, it’s not too hard really just a series of steps to take carefully and one by one.
A good cutting tool (I had one of those vibrating ‘multi tools’) and a well lit, dry space to work are key I’d say, and just take your time.
Really happy with how it came out, and at about £1800 all in including shipping from the US it felt much more justifiable than the genuine Land Rover kit at £5k or so.
NB. You’ll also need a 450/500A megafuse for the auxiliary terminal under the bonnet
Pics below:
 Cheers, David
Post #1019477 28th Dec 2023 11:09pm
Moo
Ukraine
Sweet,I like that a lot Thumbs Up I've also been looking at the Devon 4x4 set up. Eiger Grey MY23 D250 SE with bits. Known as Noddy.
Post #1019487 29th Dec 2023 1:45am
Bowbearer
United Kingdom 1985 Defender 110 200 Tdi SW Auto Baltic Blue
Good job
Looks better and more useful than the LR installation
Post #1019502 29th Dec 2023 10:17am
Cheshire110
Yep unfortunately the D44 one is a no-go with the petrol engines that have the AC fan in front of the radiator Cheers, David
Post #1019503 29th Dec 2023 10:18am
Page 1 of 3 123>
