Home > Tdi > Blue smoke on initial start up.
spudfan
Ireland
1992 200 tdi, original engine, 186,700 miles.
Noticed recently lots of blue smoke on start up. Clears once speeding up. If I stop and start later it's just the usual puff of black smoke.Runs and accelerates as normal. Any ideas? 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #1012021 21st Oct 2023 2:45pm
markb110
Have you had the intercooler to manifold pipe off to see if you have a build up of oil coming up from the intercooler then ending up in the combustion cycle?
If so could be worth removing the intercooler plus the in and outlet pipe and giving it all a clean out
With that mileage it may not have been done prior to you getting the vehicle.
Then you can normally get an aerosol product that you blast into the inlet manifold to clean that out, I can’t remember the name.
Hope that helps in some way.
Post #1012033 21st Oct 2023 4:40pm
spudfan
Ireland
I have had this vehicle from 1996. I will do the checks you suggest. Thumbs Up 1982 88" 2.25 diesel
Post #1012035 21st Oct 2023 4:45pm
Dinnu
Or the valve guide seals. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1012038 21st Oct 2023 5:23pm
NickMc
I agree with Dinnu, a top end overall would probably do wonders at the age a mileage. They’re a really easy lump to work on.
Post #1012047 21st Oct 2023 7:14pm
