Home > Td5 > TD5 Fuel Pump
Nuggie77
Canada 2000 Defender 110 Td5 SW Nato Green
TD5 Fuel Pump
How common is it for a fuel pump to fail? I have a 2000 Defender 110 TD5>
Post #1010577 8th Oct 2023 10:22pm
scotsstag
Scotland 2004 Defender 90 Td5 CSW Rutland Red
If it's still on the original pump I'd say you've done very well.
If/when you replace it make sure to use a genuine one.. 04' 90 Td5 CSW..
Post #1010579 8th Oct 2023 10:59pm
TexasRover
To replace the correct way is to drop the fuel tank which is a bit of s hassle. The alternative way is to hack a hatch in the floor plate above the pump and then cover it with a piece of aluminium. Obviously not without risk, but lot quicker
Post #1010584 9th Oct 2023 7:30am
Martin
Site Admin
As above, ONLY use a genuine LR or VDO/Continental (made in Germany) pump, not a pattern one or you'll be doing it all again before too long.
Don't be tempted by the "OEM" Lucas pumps, they are pattern ones.
20+ years is good going for a Td5 pump. I've just changed mine after 21.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1010592 9th Oct 2023 8:41am
NickMc
Yep don’t cheap out on the pumps you’ll be doing it again. 110 is easier to drop a tank out of than a 90 lucky for you.
Post #1010677 9th Oct 2023 7:42pm
geobloke
Hack?? How dare you... Shocked I will have you know the fuel pump hatch mod was surgical in its precision...
It is actually a great mod for the reason above and for the fact that this way around there is no chance of breaking the fuel pipe unions that hate to be flexed during the dropping of the fuel tank.
Post #1010680 9th Oct 2023 7:54pm
TexasRover
Oh yeah loving my inspection hatch. Previous Owner put it in for me. He also swapped the hoses around on the new cheap pump he fitted which I thought was faulty and replaced with VDO only then to make me look at the hoses finding crimp fittings and subsequent leaks. Open did the hatch go again for me to swap out the whole fuel pipe "harness" with a known good. Finally all good!.
Image doing all of that by dropping your (obviously alway full) fuel tank 4 times..
Post #1010707 10th Oct 2023 12:57am
geobloke
Rolling with laughter Rolling with laughter Oh no mixing up the connections would have created quite the issue Shocked
Goodness VDO or nothing when it comes to the fuel pump or the MAF sensor. Everything else and you are just chucking money at the wind.
Post #1010779 10th Oct 2023 7:02pm
Will.I.AM
United Kingdom 2005 Defender 130 Td5 HCPU Kaikoura Stone
Can second the need to go for genuine pump only and also closely inspecet all pipes and unions and replace where neccasary. I had to do mine as it was a noisy pump and had no end of starting issues - turned out the guy before (#1stclassbodger) had not only installed the fittings the wrong way round but the fueld was getting to the engine ciompletely the wrong way round - i.e. into the cooler and back into the engine coming back down to the tank through the regulator..... Banging Head Defender 130 HCPU TD5
Series 2a 300tdi
L663 5.0 V8
Post #1010822 11th Oct 2023 6:43am
rustandoil
I considered making a hatch in the floor when I replace the floor in my doublecab, I just couldn't bring myself to hack one of the floor braces...
Post #1010827 11th Oct 2023 8:00am
Nuggie77
Update
Hi All
I received my new pump and was ready to install when I discovered it was a different set up that what is currently in the vehicle. Photo on the left is the one I received from LR Direct claiming it is an original Land Rover part and suitable for up to a 2016 TD5. As you can see the connections are different. HAs there been any updates to this set up? The new one only has a supply and return connection and no LP return.
Post #1015671 19th Nov 2023 5:56pm
Martin
Site Admin
From the photos in your gallery you have been sent a 2.4 Puma (also 99-06 ROW spec 300 Tdi) sender.
What part number you order? LRDirect is all part number based rather than a description or category.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1015672 19th Nov 2023 6:04pm
geobloke
Well balls.... What is the model and year of your Defender mate?
Post #1015673 19th Nov 2023 6:07pm
Procta
dont buy cheap for god sake, the previous owner who had mine, had it replaced. It went on me sadly, looks like it was replaced with a cheap unit for it to go on me.
Dropping the tank isnt as a nightmare, but then again me and my dad have tackled far worse together. The only pain in the arses were, getting the fuel pump locking ring back on, getting the seals to sit etc. Then the battle was getting the tank back up, but that was due to the fact it was a full unit, which we ended up draining it out. Once that was done, we had it back up there with a little care and time. Thumbs Up Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #1017213 3rd Dec 2023 2:59am
geobloke
A bit of an old thread, but it is worth saying VDO or nothing when it comes to TD5 fuel pumps. Expensive, yes, but the chances of getting a noisy or bad one are much lower and worth the price.
Post #1017223 3rd Dec 2023 9:21am
