![]() | Home > Td5 > Injector cleaners/ fuel additives |
And that there is 2 Strokes worth IMHO... Interestingly after a good first run with 2 stroke oil in the tank the exhaust note has changed, deeper... Somehow... Cannot see how it is connected ![]() |
It is not common. There was a place in Shrewsbury years ago that sold biodiesel at the pump, but no longer. |
rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 804 ![]() ![]() ![]() |
So how much are you 2 stroke users adding per tank?
Tdi4 Member Since: 24 Oct 2014 Location: Houten Posts: 513 ![]() ![]() ![]() |
To be environmental friendly you don't only have be a millionaire but also have 3 university degrees.
![]() Because bio diesel isn't the same as HVO (also called blue diesel). HVO is Hydrotreated Vegetable Oil. And one of the plupoints is that it doesn't contain bio diesel. If still anybody is following and wants to know more just ask. a defender from 1984 pretending to be a puma with a touch of Range Rover |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2201 ![]() ![]() |
Interesting read on using 2 stroke oil with Diesel engines.
https://www.linkedin.com/pulse/truth-addin...hew-bailey The Truth About Adding Two-Stroke Oil To Diesel In Modern Common Rail Engines Matthew Bailey MAICD Matthew Bailey MAICD Matthew Bailey MAICD Executive Director @ DCARB Published Jul 1, 2016 It seems counter-intuitive to be utilizing 2-stroke oil in diesel on common rail, low emission vehicles. The actual premise behind adding 2-stroke does carry weight in certain instances. Vehicles equipped with Bosch, Delphi, or even Seaman’s fuel systems generally don’t need it. Therefore, your unlikely to see a significant change in engine performance or noise with the use of 2-stroke in diesel. However, if you have a 2005-2012 Denso Common Rail equipped system, your vehicle will most likely notice significant changes. The Theory You need 2-stroke premixed oil, at a ratio of 300-to-1. This equals about 3ml per litre, of mineral based, low-ash 2-stroke oil. The reason why this mixture creates a beneficial difference is quite simple. With Denso Common Rail operating systems, nearly all failures we have seen at Bailey’s Diesel are seizure related or seizure based failures. The injector becomes sticky; it generally loses tolerance and shows symptoms such as cold knocking. The idea behind adding 2-stroke oil therefore makes a lot of sense, because we’re adding lubrication where the main failure mode is seizure related. The other interesting thing is that when we fitted all of our injectors with DLC coated injectors, we noticed a significant difference in the engine noise and smoothness. The DLC coatings applied inside our injectors create a permanent, very hard and low friction surface . So I thought if the low friction was worth a try, we should test this 2-stroke myth, and we were surprised when it actually worked quite well. Our Conclusion So the reality is if you have genuine Denso injectors or the original injectors in the car, and it’s pre-2012, then adding a little bit of 2-stroke will create a longer service life for the injector, but also make it a little quieter and smoother in its daily operation. The general premise behind it: mineral-based, 2-stroke, low-ash and 3mil of oil per litre. Hope you enjoyed the article. Please feel free to contact me (0403) 243-786 Thanks, Matthew |
Evil Elsie Member Since: 25 Feb 2023 Location: Cumbria Posts: 206 ![]() ![]() ![]() |
Crikey..!! It's true...👍😃👍
I add 300ml to a full 75 ltr tank (I think TDi 110s have an 80 Ltd tank..??) which equates to 250:1 I actually told the MoT tester that I had 2t oil in the fuel and his response was "Hmm, this could be interesting..." but she passed the emissions test with flying colours. Happy days.... 👍👍👍 2002 Land Rover 110 Td5 Utility 1990 Suzuki GSXR 1100L 1980 Yamaha RD 350LC 1976 Yamaha RD 400C |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2109 ![]() ![]() ![]() |
Good result and good to know 👍👍
I’m not sure how “DPF friendly” two stroke oil is so I will stick to millers as a additive each time I add fuel and forte once a year.
That’s essentially what I do Ian 👍
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1189 ![]() ![]() ![]() |
I am following this subject with interest. While being sceptical I do note a quieter running of my Td5 after adding an off the shelf additive. Maybe it is cleaning the injectors but I suspect it changes the Cetane rating, like apparently 2 stroke oil does too.
Cetane rating being the octane rating of Diesel and I understand raising it makes for less diesel knock. At least so the theory goes |
Last one from me - 2t oil has different (Japanese) specs always shown on the label. The current readily available ones are;
JASO FB - the most basic 'classic' oil. JASO FC - 'middle of the road' and what I use in my TD5 (EGR blanked and no exhaust Cat). I could use 'FB ' in her but it was a four litre bottle of 'FC' on offer at Opie oils... JASO FD - the best quality - low ash, low smoke and what seems to be recommended for more modern engines. This is the one that was used by the Freelander 2 boys and the one I would go for If I had a Puma. Cheers. 2002 Land Rover 110 Td5 Utility 1990 Suzuki GSXR 1100L 1980 Yamaha RD 350LC 1976 Yamaha RD 400C |
