Home > Faults & Fixes (L663) > LED flasher fluid
DFNDER
Australia
LED flasher fluid
Just wondering if anyone has had issues refilling their LED flasher fluid?
Post #1009993 4th Oct 2023 9:25am
windy81
Wales 1992 Defender 90 200 Tdi HT Firenze Red
Up the wahs aii
Post #1010024 4th Oct 2023 1:25pm
lightning
Do you mean windshield washer fluid?
No issues on mine except you can't tell how full it is, so it will suddenly overflow while you are filling the reservoir
Post #1010463 7th Oct 2023 9:38pm
pjeski
United States
No, he means blinker fluid. It has to be kept full, or your turn signals and hazards will stop flashing.
It's like making sure you change the winter air in your tires for summer air and vice versa to accomodate the seasons.
Post #1010473 8th Oct 2023 12:57am
DFNDER
Australia
Exactly, thanks for the tip on Winter vs. Summer air, I will be sure to change mine soon, I just rotated the tyres at the first 5000km, and had to swap from lh air to rh air.
Post #1010474 8th Oct 2023 1:48am
BuckBlu110
United Kingdom 1994 Defender 110 BMW M57 3.0 Diesel CSW Buckingham Blue
This might be a good time to remind owners of the classic defender, that when upgrading from filament bulbs to led lights, that led specific fluid must be used. Drain and flush the system with your desired indicator flush, then refill with fully synthetic indicator/blinker fluid. Mineral based fluids can have a peculiar effect in the diodes.
Post #1010483 8th Oct 2023 6:47am
P50WKB
United Kingdom 2009 Defender 90 Puma 2.4 CSW Santorini Black
Surely there's only one April 1st in any 12 month period ? Rolling with laughter MY 21 3.0 D250 SE 90 Hakuba Silver (Sold October 2023)
MY 24 3.0 D250 HSE 90 Santorini Black (Bought October 2023)
2009 Defender 90 2.4 TDCi Santorini Black
Post #1010489 8th Oct 2023 7:52am
LR Nuts
you can now get a LED trafficator, which are both electrical and mechanical, so keep them oiled.
Post #1010491 8th Oct 2023 8:01am
DFNDER
Australia
thanks for the tip, any specific brands I should look for? 😉
Post #1010498 8th Oct 2023 8:57am
BuckBlu110
I can recommend Vinz synthetic advanced blinker fluid, good for 10k blinks Thumbs Up
Post #1010500 8th Oct 2023 9:04am
lightning
The indicators on my old Morris 8 stopped flashing, they were on all the time.
I tried to buy more flashes but the shop sold me the gaps, and not the actual flashes, so now they don't work at all.
Post #1010519 8th Oct 2023 2:08pm
DFNDER
Australia
How much for the gaps? I was quoted the same price per gap as per flash, but Im thinking the gaps should be 50% of the flash as the globe or led isn't actually working.....
Re the fluid, I enquired, and here in Oz I can only get "Winks" synthetic led flasher fluid, it is guaranteed for 20,000 blinks though....
Post #1010802 10th Oct 2023 11:07pm
Leamreject
Italy 2011 Defender 90 Puma 2.4 HT Fuji White
So if you change for a different viscosity of fluid can you vary the blinker timing? Whistle Ride like you stole it!!
If I’m not on a bike it’s because only a 4x4 will do…
2011 2.4 Puma 90 HT
Post #1010815 11th Oct 2023 2:48am
steam_simon
That "Winks" synthetic LED flasher is rubbish. I turned on my hazard lights and only one side worked.
You need to use "Blinks" instead. (Although my indicators no longer work now.)
Post #1010842 11th Oct 2023 9:16am
TexasRover
That's the problem with modern cars they find more and more ways for you to part with your money.
Dealer LED fluid bloody rip off that, much cheaper online.
Post #1010849 11th Oct 2023 9:47am
