Crossmember to body bracket
Sorry if this has been posted before but struggled to find it.
Had to have the crossmember replaced (puma 2.4)and the new one has the tabs to secure it to the tub. The tabs aren’t welded so can be removed, but wondering if anyone has swapped them out for the more puma like bracket that goes the whole way across? Looks like yrm offer a galvanised one (KVU101160)
https://yrmit.co.uk/product/body-chassis-m...der-later/
Will also swap the bolts for a neater stainless set with stainless and nylon washer.
2nd Oct 2023 8:07pm
NickMc
They swap like for like, the one in the picture you’ve posted should actually be fitted with the tabs on the outside, the newer type has captive nuts.
2nd Oct 2023 8:31pm
WestCountryPete
Thanks, that’s good to know. Will add it to the never ending list of jobs
I also thought the tabs would be on the outside (although glad they’re not) but from a search round it looks like they’re being fitted on the inside on pumas and late TD5s. I guess it makes very little difference, but at least I know the paints not damaged during fitting.
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
