![]() | Home > V8 > Help identifying v8 fan shroud to improve cooling? |
Linds Hanson Member Since: 16 Jan 2021 Location: Cornwall Posts: 500 ![]() ![]() |
Looks like the standard Discovery/RRC 3.9/4.2 MA on cowling, similar part was used on the NAS and Aniversary 4.0L Defenders too ESR3226
Lodelaner Member Since: 04 Feb 2010 Location: Lambourn Posts: 635 ![]() ![]() ![]() |
Agree with Linds Hanson. Should look like this.
![]() Click image to enlarge JB @Lodelaner Instagram Youtube greenlaning and other LR related content |
v8bitsa Member Since: 02 Oct 2023 Location: Herefordshire Posts: 2 ![]() ![]() |
Brilliant, thanks both! BTW, does the fan look far back to you also?
It does look slightly further back, the cowling only just clears the alternator when the engine is in the correct position. Is your gearbox/transfer box on the correct V8 mounting brackets?
Jimbob292 Member Since: 06 Nov 2023 Location: Derby Posts: 21 ![]() ![]() ![]() |
If you still suffer with hot running, try some water wetter depending on what you're running in terms of coolant, 50/50 water (distilled preferred) and water wetter will help.
The radiator does a lot of cooling for the engine coolant, oil and if an auto the transmission cooler. |
Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1750 ![]() |
To answer your question...
https://new.lrcat.com/#!/1228/12822/13206/1034/13271 As others have said its the same as Disco 1 The shroud is too but you have to make cutouts to suit the Defender V8 EFI radiator pipes as they are different to the D1. Suggest you check your viscous fan too as mine failed without a sound. ![]() Click image to enlarge |
100% check your fan, should lock up at first start, then the centrifcal forces, slowly open the clutch to free spin.
Also check the blade for any cracks, when they let go, they go! I had a blade come of my D1 v8, safe to say it shock the car, still got me home, viscous fan was still good, but replaced it, checked the water pump at the same time and replaced that, because of the cavitation damage. Also replaced the radiator with a high flow radiator from GM Radiators, honestly never looked back. ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge inside the pump was starting to erode the housing. |
Devon-Rover Member Since: 22 Jan 2015 Location: South Devon Posts: 924 ![]() ![]() ![]() |
Yeah I had this fun a few years ago.
![]() https://www.defender50th.co.uk/viewtopic.php?t=2103 Also can be found on Fb, Ytube, Insta & Twitter @4WDSouthwest |
I’d highly recommend the kit from Revtec… we were once sat on the A55 in a jam and it was 27degC outside…and that was after the climb..if it can handle that…. It also gets hammered around a track and gets used in scatter rally events.
