![]() | Home > Puma (Tdci) > '07 Puma Overheating |
andy63 Member Since: 30 Jun 2023 Location: north east Posts: 835 ![]() ![]() |
First thing I'd be wanting to know.. Is The thermostat opening.. Check the state of the bottom hoses next time it seems to overheat.. If they are still relatively cool then you have no radiator cooling..
On reasonably long journies recently my coolant temp were up to around 98 degrees but I can't remember it exceeding that.. On the couple of occosion I pulled in for a break my bottom hoses were relatively cool.. So certainly hadn't been in use a lot.. My Stat is supposed to start to open at 82deg and be fully open at 96.. But the Stat bulb will not be in the direct flow of coolant from the engine, but in the leg of the housing fed from the bottom radiator hose I think.. So it will take longer to open than the coolant temp suggests.. My thoughts anyway.. 👍 |
JackLongley Member Since: 05 Dec 2022 Location: Penarth, Wales Posts: 7 ![]() ![]() ![]() |
Thanks for the suggestion! Got the three hour drive back this evening, so I'll check. 2007, 110 Puma 2.4, Tonga Green, "Leonard"
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2509 ![]() ![]() ![]() |
Being yours a 2007 you could also remove the small thermostat on the oil cooler. As for a new coolant just pick one with the right specs (Ford WSS-M97B44-D) Puma 110" SW
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2530 ![]() ![]() |
The coolant LR rebadge and sell as LR coolant is texaco delo xlc . It’s a very good coolant and you can find it online.
