Home > Puma (Tdci) > Rear seat measurements |
Forward facing or side facing seats mate?
28th Sep 2023 9:20pm |
Shropshirelad Member Since: 28 Aug 2023 Location: Shresbury Posts: 20 |
Forward mate
28th Sep 2023 9:56pm |
Roger that. Can’t help you I only have the bolt holes for the side facing seats.
28th Sep 2023 10:16pm |
Snowy90 Member Since: 23 Feb 2015 Location: Surrey Posts: 482 |
Click image to enlarge Click image to enlarge 0.425m or 42.5cm Does that help. |
29th Sep 2023 8:35am |
Legend!!
29th Sep 2023 3:25pm |
No probs, hope it helps
2nd Oct 2023 9:03am |
Any chance you could take a photo of where your belt mounts into the tub floor and posssibly underneath?? Trying to mount my belts but not sure where to mount them? Thanks in advance!!
3rd Oct 2023 6:25pm |
Click image to enlarge Click image to enlarge Click image to enlarge Any Good |
4th Oct 2023 9:09am |
That’s amazing. So do the end of the belts just bolt through the floor with no bracket back to chassis? Just some sort of plate underneath??
4th Oct 2023 1:43pm |
Thats right look like they have a reinforcing plate behind and some form of stud bolt to stop them spinning.
4th Oct 2023 1:46pm |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3446 |
No, there should be brackets going to the rear crossmember outriggers. Such as this one from YRM.
https://yrmit.co.uk/product/rhs-rear-seat-...-defender/ There is also a spreader plate that bolts from top of the tub to this bracket. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
4th Oct 2023 2:09pm |
Thats interesting i dont have that?
4th Oct 2023 2:39pm |
You are right, i do have something like that, its just caked in mud and hidden behind the filler tube.
So yes you do need additional brackets/bracing. |
4th Oct 2023 2:47pm |
The originals tend to rust pretty quick and blend with rest of the environment 😉 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
4th Oct 2023 2:50pm |
