Home > Maintenance & Modifications > A/C condenser
steveww
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Bronze Green
A/C condenser
The A/C condenser (the rad at the front) on my Puma is on its last legs. A lot of the fins are detached and it's all a bit wobbly.
The genuine LR part is jolly expensive, I see on FleaBay there are companies selling alternatives. Anybody got any experience with these?
Post #1009141 27th Sep 2023 4:12pm
bankz5152
Yes!
I bought one + a Spal fan, they fit with some minor adjustment of the AC lones and you need some 10mm spacers for the bottom. Its a TD5 but same partnumber as the pumas
 Instagram @defender_ventures
Empire Tuning - Agent
Post #1009143 27th Sep 2023 4:21pm
TexasRover
Did you have to remove the frame?
Post #1009151 27th Sep 2023 4:57pm
bankz5152
The LR AC condensers are part of the frame, cant be bought separately unless count YRM one.
Its a whole new unit Instagram @defender_ventures
Post #1009157 27th Sep 2023 5:45pm
TexasRover
Ok understood so you did/could not fit the condenser in the old frame and fitted without the frame instead or am I seeing that wrong.
Post #1009161 27th Sep 2023 5:59pm
geobloke
There is no frame in Bankz setup.
The aftermarket AC condensers also use a solid frame to replace the bonnet struts.
Post #1009165 27th Sep 2023 6:09pm
bankz5152
The condensers come with the frame. They are not available separately. To remove the condenser means removing the frame as they are one item.
The condenser I have has no frame and is a larger condenser overall. Fits in the original position with some.minor bending of the AC lines. Instagram @defender_ventures
Post #1009167 27th Sep 2023 6:16pm
WilkoW
United Kingdom 1998 Defender 90 V8 Petrol 50th Auto Atlantis Blue
I’ve no experience with eBay sellers but can recommend Coolair Logan.
Post #1009913 3rd Oct 2023 2:16pm
steveww
I contacted Coolair Logan and they offer the JLR unit at a very competitive price and their own design for about half that. Their own design is said to offer greater efficiency with better fins.
I order their version which looks to be an exact fit. I'll know for sure once I try to fit it in a few days when my A/C man can empty the system.
Post #1029616 28th Mar 2024 3:35pm
steveww
The Coolair Logan unit is an exact fit.
I had a local shop suck out the gas, I swapped over the condenser and the shop put the gas back in. The old unit has seen better days. Remember to replace the O rings on the connectors, they're expensive at about 4 quid each Shocked
Post #1031057 9th Apr 2024 10:14am
MCGreen
United Kingdom 2012 Defender 90 Puma 2.2 HT Aintree Green
Hi Steve,
What was the cost? no prices on Coolair Logan website don't want waste their time if still too much for me.
Thanks Matt
Defender 90 HT 2.2 Puma
Post #1031059 9th Apr 2024 10:28am
steveww
The Coolair Logan condenser was £390 all inc.
Post #1031062 9th Apr 2024 10:39am
carrotbay
United Kingdom 2008 Defender 110 BMW M57 3.0 Diesel XS CSW Auto Santorini Black
Hi Steve
Is the CoolAir Logan condenser including the frame and fan?
Thanks 2008 Defender 110 XS SW - M57N2 / 6HP28X
Post #1037145 11th Jun 2024 5:07pm
steveww
Yes, just like the factory one only better and less expensive.
Post #1037147 11th Jun 2024 5:11pm
carrotbay
Great - thank you. I’ll get one ordered tomorrow 2008 Defender 110 XS SW - M57N2 / 6HP28X
Post #1037157 11th Jun 2024 6:24pm
