"A" pillar lower trim rubbing on wing
Has anyone else had this issue where the lower A pillar trim rubs the paint on the wing.
Is it possible to remove these lower trim pieces without damaging them? l may file a bit off the lower edge to stop it from touching the top of the wing.
26th Sep 2023 8:38am
Hairy Dan
Mine isn't rubbing, to remove it open your door and pull the trim from here
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
