Home > Td5 > Starting Issue - Inconsistent
CJs110
Canada 2003 Defender 110 Td5 SW Zambezi Silver
Hi Guys,
My TD5 (2003, 110, manual) has been having some starting issues.
I turn the key to on, wait for glow plug light to go out (I can hear fuel pump). Then I crank and all it does is crank and crank and crank. No start - almost reminiscent of a petrol engine without spark.
So I turn the key to the off position and wait a few seconds before trying again.
Usually I do this between 2-5 times before it starts. Sometimes it works first try barely any cranking!
Also on cold starts, it does blow some grey smoke which smells like unburnt fuel (when it doesnt start the first time).
So where do I go from here? I have tried/done the following:
-Battery fully charged (<1y/o)
-Fuel pressure at the regulator block (tested with the HP line disconnected)
-Fuel pressure regulator block rebuilt - seals
-Fuel connections at pumped checked/new fuel filter
-Crank pos'n sensor replaced twice (I also tried it with a crank pos'n spacer which I read is for manual trans only, but this just led to the car not starting at all - would just crank endlessly, so I removed the spacer)
-Injector harness was replaced in March by PO, I cleaned the plug coming out of the head and I cleaned the ECU connector at the ECU (yes there was a bit of oil)
Really not sure what to do next? I have read that the starter - even if it works can cause interference with the crank sensor? I am wondering what cycling the key "resets" or if its just by luck that the stars align and the car starts?
Other points to note, it is a bit rough at idle but otherwise drives normal, doesnt stall, doesnt blow smoke (aside from cold start as mentioned).
Post #1008867 25th Sep 2023 9:28pm
landy andy
Have you changed the injector washers?
Before starting the vehicle do the pump priming procedure and wait for it to finish before trying to start it. During this you should hear the pump doing it’s thing, but shouldn’t hear lots of air noise.
Post #1008873 25th Sep 2023 9:35pm
LandymanStefan
England 2001 Defender 90 Td5 SW Epsom Green
Check the cable from the crank sensor to the ecu. Consider getting an independent loom for the crank sensor to the ecu so you can rule out the wiring.
Ideally find someone with a nanocom and watch it as you crank, i has this issue with mine and you could see the engine speed reading as 0rpm when cranking. I tried crank sensors, i changed my cabling as mine was in poor condition (could see copper in places). I still had the problem after this and the last thing in the circuit was the ecu itself. Changed that and it’s been fine since.
Post #1008874 25th Sep 2023 9:37pm
CJs110
Thanks for the replies.
Andy, I will have to check with PO if the injector seals/washers were done. Does this more so relate to the rough idle or the hard to start? Do you think a bad seal/washer is flooding the engine with too much fuel?
I generally use the bleed method when I go to start the car after a few days. Again this hasn't guaranteed the car to start first try.
How can I determine if its a lot of air in the system? I feel I hear the pump loud(ish) when using the prime procedure, but not sure what to listen for to determine if there is air?
Stefan, I will take a look at the sensor loom. I do recall it being a bit on the crusty side. A nanocom is definitely on the wishlist, in the meantime if there is anyone somewhat local to Windsor/Chatham in Ontario would be so kind as to plug in? Bow down .
If it is an ECU, is the process getting a replacement or having the original rebuilt? Thanks
Post #1008898 26th Sep 2023 1:53am
rallysteve
Injector seal issue is the opposite way around, during running the combustion gasses pass the copper washer and enter the fuel gallery in the cylinder head. After you have stopped the engine, this gas pocket tends to accumulate around some or all of the injectors meaning when you try and start next time, there is no fuel at/in the unit injectors to be pressurized and injected.
When you turn the ignition on and hear the fuel pump, do you hear any gurgles or noises like air bubbles moving around the system (worth doing the fuel purge routine mentioned above though) as this is a telling symptom of injector seals.
The starter motor can supposedly also cause interference which prevents the crank sensor from getting an accurate reading but I suspect this is often only the case when the original crank sensor (shielded) cable has started to break down.
Post #1008924 26th Sep 2023 11:43am
geobloke
Agree with rallysteve here.
The most intermittently Miffy has ever been was after I fitted a OEM starter motor (very close to the CPS and wiring loom), it was so incredibly noisy (electrically) that it over-powered the CPS signal. Replaced with a Denso starter and the problem instantly resolved itself.
If you want to quickly try something to discount signal interference, wrap a load of tin foil around the CPS wiring and see if it helps. This should help shield the signal from possible noisy electronics. The other option is to make yourself a stand-alone by-pass CPS loom back to the ECU. It is not a difficult job to do DIY. I removed my by-pass loom after changing the starter and the standard loom has been fine, so that shows how awful that cheaper starter motor was.
Post #1008928 26th Sep 2023 11:55am
geobloke
You mention you changed the fuel filter. Have you replaced the fuel filter housing as well? The fuel really shouldn't drain from the engine back into the tank in a few days enough that you need to do the system priming.
The fuel filter housing can be the location of a few fuel issues.
    The first is if the ports are connected up wrongly.
    The second is if the one way valve and bleed valve are in the wrong ports or faulty.
    Finally, if the housing (cast aluminium) has corroded enough to allow air to be drawn into the system.
All of these could produce intermittent starting issues related to fuel draining back to the tank.
These are the posts I made on the subject https://www.defender2.net/forum/topic53859...;start=255
The position of the one-way valve can be in a different position depending on the age of MY of the TD5, but the bleed valve (I believe) is always in the same location. The 10P engines (pre-EU3) didn't have the one-way return valve, it was an addition for the 15P (EU3) engines, like we have. Miffy is also a 2003 TD5 and the one-way valve is in the rear right port, not the rear left port. Worth checking where yours are.
In this image you can see how corroded the housing became at the ports, almost all of the material has corroded away next to the copper washers. You can also see where my one-way and bleed valves were located from the factory.
For info: There was a Tech bulletin RE TD5 staring issue in 2004 regarding the condition of the bleed valve sealing o-ring - http://gershon.ucoz.com/landrover/TD5/TOPI...oisy_F.pdf
For reference: CPS by-pass loom posts https://www.defender2.net/forum/topic53859...;start=240
Post #1008934 26th Sep 2023 12:43pm
Green Machine
Also see my post here:
https://www.defender2.net/forum/topic88475.html
May not be the issue, but if your relays are the originals, they probably aren't in great condition. Mine is a 2005 and they were in pretty bad shape. Mine was doing just as you describe (continuous cranking with no attempt to actually start).
The only difference with what you describe is that I noticed on the occasions when mine wouldn't start, the engine management and glow plug lights didn't illuminate on first ignition position. On occasions when it would start, those two dash lights did come on first.
Can't say for certain that yours is the same issue, but after swapping my relays (under the driver's seat) for new ones several weeks ago, I haven't had a single non-start issue since. 2005 Td5 | 90 Station Wagon | Tonga Green
Post #1008990 26th Sep 2023 4:36pm
CJs110
Steve
Thank you for the explanation. So bad seals result in more difficulty starting the next time. Yes when I do turn the ignition I do sometimes hear something of a alternating high & low pitch "whine" from the pump - like it changes tones. I will take a closer listen and see if I can get video to see if it is more like a gurgling noise. Meantime I will add a injector seals set to the order list. I think injector seals/washers and a rocker cover gasket? Or since the gasket was replaced in March should be ok?
Sorry not sure how to add multiple quotes to one reply
But thank you geobloke. I am going to try the tinfoil in this weekend while I get some wiring to make a separate loom and try that out for the CPS. Thank you for the links.
Very good point about filter housing, no I did not replace that so that is definitely a place I will check as well to see
And Green Machine thank you for the insight. Likely the relays are all original so definitely would be worth checking. Is it one specific relay that affects this system or should I be looking to replace the lot? Interesting you mentioned the dash lights, because regardless if the car does/doesn't start the lights do some on at the first position.
Thanks all for replies, it gives me a number of things to try and look at during the weekend!!![/list][/quote]
Post #1009298 28th Sep 2023 7:20pm
Green Machine
I suspect that it was the main relay on mine (because I was told this is the one that is most likely to be causing the non-start issue) however I neglected to do any thorough testing. I just ordered replacements for all 3 relays (main, glow plugs, and fuel pump) and replaced all of them at the same time.
The LR Specialist that I have used previously (and asked advice from about this issue) said that relays should be considered a service item on Td5 Defenders. Beyond 10 years old, they cause an array of problems and are usually his first 'port of call' for electrical gremlins. 2005 Td5 | 90 Station Wagon | Tonga Green
Post #1009918 3rd Oct 2023 4:32pm
CJs110
Update 10/12
Hi Everyone. Thanks for all the insight. So far ordered:
-Injector seals/washers (Arrived)
-Filter housing repair components as per what geobloke wrote (arrived & installed)
-New relays (haven't arrived yet for some reason?)
So the first thing I tried was aluminum foil around the CPS wire. I may have done a pretty bad job wrapping it, because it made no difference. Still inconsistent starting. I have some wire and a connector end I will make a standalone wire and route away from the starter as was suggested and see if there is a difference.
Next thing, the filter housing repair components came in and I removed the old (see below)
Replaced with the following part numbers:
Filter housing looked good, sealed well when reinstalled. Very easy repair, my one-way valve was in the same location @geobloke - makes sense both 2003's. But the repair did not make a difference. Still refused to start until I cranked, off, & cycled the key like 4 times.
Next steps: Relays when they come in, CPS standalone harness, still hoping someone in Ontario nearby has a Nanocom? Smile
I am holding off on the injector washers at the moment (parts have arrived) until I have the garage cleared enough and the time to start that repair. (It is getting colder and I dont fancy cracking open the rocker cover outdoors).
Thanks again, will keep everyone updated!![/img]
Post #1011001 12th Oct 2023 4:41pm
Hazza
United Kingdom 1990 Defender 110 Td5 HT Bronze Green
There is an alternative way to rule out an electrically noisy starter - bump or tow-starting. This removes the starter from the equation. 1990 Defender 110 200TDI Camper - now converted to Td5 power
Post #1011477 16th Oct 2023 8:21pm
CJs110
UPDATE: Starting Issue - Inconsistent
Hi Everyone,
It's been a while since I replied. A number of things have happened since then!
I finally got around to the injector washer/orings. They actually weren't too bad (bit of crud on the washer but all the orings were great). That said everything was out so I replaced them.
- No difference still same starting issue
Then I tried the starter with a push start (2nd gear). I had my brother push a few times and couldn't get it to go? So I was thinking, ok likely NOT the starter. But wait!! It happened that I saw the OEM Denso for a good price so I picked one up. I tossed it in and boom!!
(Old starter)
It starts now everytime hot or cold!! BUT!! And unfortunately there is a BUT. The key word is that it starts everytime now, but on cold starts (anything where the car has sat 8+ hours) it starts and dies immediately? It needs to be started a few times/accel pumped to attempt to get it to idle. Warmed up there is 0 starting issues.
Any thoughts or advice? I am thinking the reason the push start didnt work is due this issue.
I have previously done the filter bleed/valve repair, that said at the time the housing looked bad worth replacing? Or is it the fuel pump? Again appreciate the advice and sorry for the lengthy absence (I really had to hype myself up to do those injectors with the cold weather)
[/img]
Post #1031377 12th Apr 2024 9:13pm
NickMc
Two things I’d try the ground post in the Seatbox where the ecu lives, feed a separate ground and see if that improves.
The 10AS box look and see for water damage. They’re getting old and temperamental now.
Post #1031379 12th Apr 2024 10:39pm
