Home > Technical > 1.2 or 1.4 ratio transfer box |
MatLandy Member Since: 11 Sep 2020 Location: Paris Posts: 191 |
The blue "1.211 RATIO" sticker on the box is typical of Ashcroft recon units. The 43D engraving is clearly not the original engraving on enclosure, and has been superposed. This is also typical from Ashcroft recon units where they alter the first digits on the recon units they send you to match what was original on your car.
At least the above is my experienced when I bought the current transfer box from them on my Puma, I was asked to supply the serial number of the original box (81DXXXXXXX which was the factory fitted 1.211 ratio), and guess what .. a recon unit showed up with 81D engraved on top of 23D. So I am now running with a transfer box enclosure from a D1 or RRC. However what's inside is different (ATB + 1.1 ratio) Hope this makes sense ? /Mat Click image to enlarge Last edited by MatLandy on 21st Sep 2023 1:08pm. Edited 1 time in total |
21st Sep 2023 12:26pm |
charcoal Member Since: 28 Jul 2014 Location: Hampshire Posts: 942 |
Thanks matt, yes it does make sense. If it has been successfully converted to 1.2 ratio what else could be causing it to feel like a 1.4 still? I cruise at 60 and the engine is getting loud at that point, can push it to 70 but it really is running hard at that point and wouldn't try pushing it further. 1999 Land Rover Defender 110 td5 station wagon
1998 Land Rover Defender 110 County Station Wagon ~ Sold 1995 Land Rover Defender 110 V8 Station Wagon ~ Sold 1985 Land Rover 110 ex mod project Tithonus ~ Sold |
21st Sep 2023 12:52pm |
Chicken Drumstick Member Since: 17 Aug 2020 Location: Near MK Posts: 784 |
A rev counter will tell you your rpm at a given speed. Probably the easiest way to see.
21st Sep 2023 1:01pm |
Ordered a ten quid tacho off ebay, should be here in the next few days although I'm off on a work trip soon so probably wont be able to update this for a while but will post the rpm at 60 on here as soon as. If any of you are running the same box could you tell me what the rpm should be on 235s at 60? 1999 Land Rover Defender 110 td5 station wagon
22nd Sep 2023 12:07pm |
andy2111 Member Since: 17 Oct 2021 Location: Kent Posts: 368 |
I have the 1.2 ashcroft ratios so I'll look at the RPM at the weekend. Will be interesting to compare my results with others too.. TD5 hardtop to Puma inspired Poptop - my build thread
2002 110 TD5 Hardtop ¦ Full Puma interior ¦ Carpathian grey / Santorini black ¦ X-Vision-X poptop |
22nd Sep 2023 12:08pm |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6633 |
On 235s, with a 1.4 box 60mph is around 2500 rpm
1.2 box it's a smidge over 2000 rpm. 1988 90 Td5 NAS soft top 2015 D90 XS SW |
22nd Sep 2023 12:23pm |
Thanks Andy will be great to know and thanks Martin that's exactly what I needed to know. 1999 Land Rover Defender 110 td5 station wagon
22nd Sep 2023 1:20pm |
Silly me I just realised I have an obd reader that can display engine speed! So I went for a quick run down the motorway and at 60mph gps speed the engine is sitting at 2130-2170rpm. At 60mpg speedo speed we are sitting at about 2070-2120rpm. This sounds pretty close to what you were saying Martin so I think this confirms it 1999 Land Rover Defender 110 td5 station wagon
22nd Sep 2023 2:48pm |
A handy resource for calculating engine rpm: https://ashcroft-transmissions.co.uk/ratio-calculator/
Click image to enlarge |
22nd Sep 2023 3:08pm |
Pretty neat, looks like all of my engine speeds very closely matched that chart! 1999 Land Rover Defender 110 td5 station wagon
22nd Sep 2023 5:49pm |
