![]() | Home > Td5 > TD5 lumpy at high RPM |
I would begin with the crankshaft pulley for 1, they can cause some interesting rough running. Check the injector balancing as this could highlight the ECU trying to balance out the poorly crankshaft pulley.
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5842 ![]() ![]() |
Are you sure the wastegate is completely free?
Chriswb84 Member Since: 16 Sep 2023 Location: North West Posts: 22 ![]() ![]() ![]() |
Hi I was thinking possibly the wastegate, but it was very loose once I had worked it free. I'll go back for a second look anyway as it's easy enough to check.
The crankshaft pulley is on the to-do list, it's telling me something isn't quite right everytime I shut it off. Thanks |
