![]() | Home > General & Technical (L663) > Wiper jets |
LR Nuts Member Since: 10 Aug 2022 Location: UK Posts: 1214 ![]() ![]() |
I only have one jet per wiper ........ and neither jets is NOT heated !!!!!
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3698 ![]() ![]() ![]() |
What MY are you? I’ve got 3 or 4 jets per wiper, mounted on the wiper itself.
MY20
Twin jets per wiper NOT heated, in my day you needed to order The Cold Climate Pack !!! even global warming isn't helping. ![]() |
jimjamken Member Since: 01 Mar 2023 Location: Surrey Posts: 88 ![]() ![]() |
It’s a MY24 and it just seems so strange to have one jet per wiper….makes me think it’s a manufacturing miss!!
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2945 ![]() ![]() |
My 2022 has three jets l think. Apparently they are heated because l ordered the "cold climate pack" but l can't see how they can be as there's no wires going to the wiper arms.
Does it work well? lt may be an update as people have complained about the wash/wipe not being very good. |
could the liquid be 'pre-heated' under the bonnet, before being pumped out to the wiper ? (Patent Pending ![]() |
I've come from a BMW which had really efficient wipers and the Defender ones seem archaic! The jets spray the lowest arc of the window with most of the water going up the sides of the windscreen and onto the door windows......really not impressed. I can't believe that the Cold Climate pack means you get more jets....I get heated jets etc but not more! |
On closer inspection there are two washer jet fixings to each arm - see photos.....it's just that only the smaller fixing actually sprays!!! I'll have to speak to the dealership about it as it must be a fault.
![]() Click image to enlarge ![]() Click image to enlarge |
Sorry to be a downer but the Webasato "Hot Shot" beat you to this money maker... Mind you not sure you can buy it anymore... |
camelman Member Since: 27 Feb 2013 Location: Peak District Posts: 3386 ![]() ![]() |
The good old Webasto Hot Shot. You've just reminded me I've got one sitting in the garage that I need to get around to fitting!!
Ahhh I have always wondered if they actually work
Tim in Scotland Member Since: 23 May 2007 Location: The Land that time forgot Posts: 3753 ![]() ![]() |
I have a March 2023 90 HSE and 4 jets on each wiper, but the wipers are hopeless for removing dead bugs, even freshly killed bugs, no matter how much water gets sprayed on the glass. My Feb 2020 built 110 had much better wipers Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed! |
AmL Member Since: 22 Jan 2016 Location: Devon Posts: 30 ![]() ![]() |
My wife's 23 90HSE appears to have 3 jets per wiper and they work perfectly well clearing mud and bugs, no problems so far
